Page 5 of 5 1 2 3 4 5
#992625 - 07/20/17 04:50 AM Re: Lower front brake hose burst - R1100RT [Re: Jim Moore]
Reecehk Offline
Reecehk  Offline
South Australia
Thanks a lot guys, I am confident that all is ok, I do hope I didn't damage the ABS unit though, I guess I won't know till I test ride the bike. Once that is done I will post here again but may not be for a while.
Cheers,
Reece.
#992704 - 07/21/17 07:21 AM Re: Lower front brake hose burst - R1100RT [Re: Reecehk]
Reecehk Offline
Reecehk  Offline
South Australia
I put the seats on, left the Tupperware off, added a little petrol and gave it a test.
No ABS faults!
Front and rear brakes work well, the rear is a lot more touchy than before.
No petrol leaks, one thing is that the choke idle speed is much higher (2k), possibly the new fuel filter?? confused
All in all a very happy chappy!! yes
Thank you all for the much appreciated help/guidance. thumbsup
#992716 - 07/21/17 01:17 PM Re: Lower front brake hose burst - R1100RT [Re: Reecehk]
szurszewski Offline
szurszewski  Offline
Portland, OR
The "choke" on your bike is really just an additional throttle cable and does the same as if you were just holding the throttle/twist grip open a bit. Could be just easier access to fuel/air now or the cable might have been "adjusted" by your service work inadvertently - as long as you have the plastic off, maybe check to make sure it's not hanging up on anything.
*insert witty remark here*
#992757 - 07/21/17 10:18 PM Re: Lower front brake hose burst - R1100RT [Re: szurszewski]
tallman Offline
Picture Perfect Humorist
tallman  Offline
Tallahassee, Florida
and then adjust to proper range...
If my mind wanders, should I follow it?
Tim
Conch Town Krewe
2003 K 1200 GT
1996 R 100 RSL
1980 R 100 RT
1972 R 75
1968 R 50
All now gone...
#1000666 - 11/10/17 11:44 PM Re: Lower front brake hose burst - R1100RT [Re: tallman]
Reecehk Offline
Reecehk  Offline
South Australia
Hi, been a while since I checked here, yes I will have to adjust the choke.
I have to start a new thread since the bike has now died!!!
#1000778 - 11/12/17 10:25 PM Re: Lower front brake hose burst - R1100RT [Re: Reecehk]
Lowndes Offline
Lowndes  Offline
Roswell, GA
Reecehk,
Re: "...one thing is that the choke idle speed is much higher (2k), ...", you might want to check the "choke" cable from the handlebar to the Bowden box, make sure all the cable sheaths are fully seated.
Old Fart Newbie
#1001012 - 11/16/17 03:21 PM Re: Lower front brake hose burst - R1100RT [Re: Reecehk]
philbytx Offline
philbytx  Offline
Kerrville, TX
Make sure the RH side throttle cable is properly seated at the Throttle Body end......!
Phil C.
2003 R1150RT "DaRTh"
2014 Jeep Grand Cherokee Overland 4x4 Diesel "Smiffy"
2011 Kia Optima EX "Meosjin Chalo"
Page Time: 0.009s Queries: 16 (0.003s) Memory: 2.7786 MB (Peak: 2.9449 MB) Zlib enabled. Server Time: 2018-02-24 07:41:29 UTC
