Page 2 of 2 1 2
#1000767 - 11/12/17 04:51 PM Re: Adjusting brake pedal height [Re: Rob L]
Rob L Offline
Rob L  Offline
Merrillville, IN, USA
https://imgur.com/ZOfgVVs
This is the clevis.
https://imgur.com/outXnMP
I removed the pin and shortened the threaded rod a bit
https://imgur.com/mPpprfh
this is after I shortened and reassembled the pedal
Rob - Da Region
Quartz Blue 2014 Wethead RT buyback
Honda CH80s (2 of them, black and white, his and hers)
#1000768 - 11/12/17 05:10 PM Re: Adjusting brake pedal height [Re: Rex R]
Rob L Offline
Rob L  Offline
[Linked Image]
The rod may be too long. Remove the clevis and grind off a few threads.
[Linked Image]
I also left the locknut off to shorten the distance between the clevis and the master cylinder even more. Use locktight on the threads instead.
Rob - Da Region
#1000775 - 11/12/17 09:38 PM Re: Adjusting brake pedal height [Re: Rex R]
AndyS Offline
AndyS  Offline
Somerset, Great Britain.
Hi Rob, not keen on the 'no lock nut'. How about drilling a tiny hole in the piston rod UNDERNEATH the clevis...then lockwire it to prevent shaft rotation.
#1000824 - 11/13/17 01:06 PM Re: Adjusting brake pedal height [Re: AndyS]
Rob L Offline
Rob L  Offline
You would need to remove the master cylinder to drill the hole. Not keen on that either........ I did this a year ago when I added the lowered foot pegs. Over 10,000 miles and no problems.
Rob - Da Region
#1000830 - 11/13/17 01:59 PM Re: Adjusting brake pedal height [Re: Rex R]
AndyS Offline
AndyS  Offline
Why would you need to remove the Master Cylinder? Just do it in-situ.
#1000884 - 11/13/17 11:00 PM Re: Adjusting brake pedal height [Re: AndyS]
Rob L Offline
Rob L  Offline
the rod can turn (revolve) and move sideways. It would need to be held stationary (in vice) to drill a hole. The clevis and rod would need to be drilled together. I feel that the lock-nut is a bit of overkill and really not necessary, however, your bike, your decision.
Rob - Da Region
Page 2 of 2 1 2
Page Time: 0.008s Queries: 16 (0.002s) Memory: 2.7666 MB (Peak: 2.9253 MB) Zlib enabled. Server Time: 2018-12-12 06:30:43 UTC
