Page 2 of 2 1 2
#1003235 - 01/06/18 02:43 AM Re: 02 1150RT Fairing Screws [Re: Bert Remington]
Cap Offline
Cap  Offline
Fort Collins, CO
Originally Posted by Bert Remington
I recommend DesmoParts on eBay for a full kit of stainless steel screws for the fairing and other items. Zenko is okay but limited to fairing screws only.
Thanks for the recommendation. I checked them out. What I noticed is that all the kits I found on ebay had screws with flat tips. I like the pointy ends on my OEM screws. Any thoughts on where to find those pointy screws? Other than BMW?
#1003244 - 01/06/18 01:06 PM Re: 02 1150RT Fairing Screws [Re: Bert Remington]
ltljohn Offline
ltljohn  Offline
Haycock, PA
+1 on the DesmoParts kit. I used this on my RT it has everything you will need.LINK
"I've received many honors but I've already received the highest award I'll ever receive, and that has been the privilege and honor of serving proudly in the United States Navy." RADM Grace Hopper
#1003255 - 01/06/18 06:37 PM Re: 02 1150RT Fairing Screws [Re: ltljohn]
nrp Offline
nrp  Offline
Minnetonka MN
Step up to a grinder with a flat-ended screw being held in a pair of nuts and a big vise grip. Use a hex key (or whatever) to keep the screw from rotating as you grind the taper to your heart's content. Polish the taper with a wire wheel. The taper is important to draw things together without crossthreading.
#1003257 - 01/06/18 07:49 PM Re: 02 1150RT Fairing Screws [Re: gmarktbone]
Bert Remington Offline
Descanso CA
Cap -- I had a mixture of "pointy" and regular fairing screws, some with Torx heads. I carefully sorted them out. I use DesmoParts' regular screws for the easy locations (eg, around exhaust pipes) and the pointy screws for the difficult locations (eg, top of gas tank). I ain't that talented with a grinder to make pointy ends. smile
2000 BMW R1100RT
2016 Royal Enfield Classic 500
#1003284 - 01/07/18 07:38 PM Re: 02 1150RT Fairing Screws [Re: gmarktbone]
nrp Offline
nrp  Offline
Minnetonka MN
Try the nut/visegrip/grinder with a hex (or whatever) key trick to control its rotation. It is really quick and easy, but it does require a fixed grinding wheel, and not a portable one.
#1003321 - 01/08/18 06:25 PM Re: 02 1150RT Fairing Screws [Re: nrp]
Lincoln_Faller Offline
Taos, New Mexico; Ann Arbor, M...
I was wondering why there was all this talk about grinding points onto aftermarket screws for fairings, which seems like a lot of trouble to go to, when the screws are still available from BMW. Then I checked the price: $3.97 each! Incredible. Didn't know how lucky I was when a couple extra showed up after my last servicing. But that wasn't from a dealer.
Lincoln
Taos, NM/Ann Arbor, MI
2002 R1150RT red
2001 R1150GS, black
1978 R100S smoke red
1967 R69S black (of course)
#1003331 - 01/08/18 08:41 PM Re: 02 1150RT Fairing Screws [Re: gmarktbone]
TheOtherLee Offline
TheOtherLee  Offline
Wilsonville, Oregon, USA
Quote
$3.97 each!
That is a fine example of a real BMW screw!
Channeling farfegnugen since 2011.
#1003350 - 01/09/18 02:19 AM Re: 02 1150RT Fairing Screws [Re: gmarktbone]
PAS Offline
PAS  Offline
N.E.Ohio
Those screws are pointed for a reason!
Page 2 of 2 1 2
Page Time: 0.010s Queries: 16 (0.003s) Memory: 2.7827 MB (Peak: 2.9546 MB) Zlib enabled. Server Time: 2018-07-19 13:33:59 UTC
