#1020756 - 10/12/18 03:03 PM Harsh Shifting?
Cohiba54 Offline
Cohiba54  Offline
Richmond, Tx.
Try preloading the shift, kind of like when doing a power shift without using the clutch. For this you do use the clutch and throttle as normal, but ahead of that sequence preload the shift leaver. This will help smooth out the last bit of systematization within the transmission. Works on up or down shift but will take a few tries before you get it. I discovered this on the K1200LT, it had a big clunk 1st. to 2nd. too.
Rene
Current
2015 R1200RT
Past
'04 R1150R
'02 R1150R
'00 K1200LT
'88 Concourse
'72 Bonnie 650 Chopper
'72 CB750K stolen
'69 SL350K gave it back to my buddy
'70 CT70 I don't remember but it was fun
#1021277 - 10/20/18 04:32 PM Re: Harsh Shifting? [Re: Cohiba54]
TEWKS Offline
TEWKS  Offline
Tewksbury, MA.
Shifts Like Buttah! grin Good tip and technique. thumbsup
Pat
"If at first you don't succeed, keep on sucking till you do succeed" Curly Howard
#1021310 - 10/21/18 12:37 PM Re: Harsh Shifting? [Re: Cohiba54]
PadG Offline
PadG  Offline
Solon, OH
I have never had to use anything like pre-load in my shifting! Downshift on any bikes should never be a problem, and if it is, I think that you need to find an old-timer to show you how to "rev-match". I never even knew that's what it's called until recent years, but that's how every riders that I knew downshift on a bike when I started riding in the '60s! smile
The wetheads "can" have clunky upshifts, especially in lower gears, and at low speed and acceleration, BUT it is possible to get noiseless shifts, once your bike is broken in "properly", like mine, and you also have to learn some techniques (beside pre-loading) for noiseless and smooth shifting at low speed. I guess the only place where I think pre-loading can be handy is when you shift from neutral to 1st, BUT then my bike is never in neutral when I ride, and it's always parked in 1st, which is another old habit! I can never understand why any one would park in neutral, but there are several reasons why one should always park in 1st!
Want to hear noiseless shifting? Watch this video of the highlight of one of my recent ride, on my '15 RT. The microphone is attached to the front of my jacket, about 1/2 way down, and so the audio is everything that one would hear from the bike. Watch on a desktop computer, otherwise the audio is likely to sound a little tinny!
https://youtu.be/npl0LeYQpj4
2015 R1200RT (San Marino Blue Met.)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Bonneville
1960 Triumph Thunderbird
1952 Triumph Thunderbird
1932 Tr. Tiger 500
1952 BSA Goldstar
#1021349 - 10/21/18 11:35 PM Re: Harsh Shifting? [Re: Cohiba54]
alegerlotz Offline
Newer Member
alegerlotz  Offline
Newer Member
Greater Los Angeles
My 2016 shifts great using the clutch or the Shift Assist Pro. I don't employ any special techniques, I just ride it....
2016 R1200RT
2007 KTM 450 XC-W (10/17 - 5/18)
2005 R1200RT (2/2015 - 12/2016)
1987 K100RS (12/2015 - 12/2016)
1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
#1021688 - 10/29/18 12:46 AM Re: Harsh Shifting? [Re: alegerlotz]
Knobby10 Offline
Knobby10  Offline
West Lafayette, IN
I've found most of my clunky shifts are caused by my poor clutch/shift timing and just not being "ahead of the bike."
'16 BMW RT Wethead
'03 KRS Blu/Wht sold
'05 Suzuki Bandit 1200S sold
'07 Ducati S4RS Monster sold
'13 Harley Streetglide traded
#1021759 - 10/30/18 01:53 PM Re: Harsh Shifting? [Re: Cohiba54]
Paul De Offline
Paul De  Offline
Milwaukee Wisconsin, USA
With Shift Assist Pro preloading the shift lrever will execute the shift, so that technique is not so useful on bikes with that feature.
Even with SAP I tend to use the clutch on down shifts as I am smoother when tooling around with the my wife on board than the computer and when riding frisky I have had a few SAP down shift delays on execution which can get scary if you are even slightly stuffing it into a turn. But even my '15 RT which is not known to be the smoothest shifting machine is sooo much better than my '99 that I'm not complaining. Is it snick smooth like the best shifting bikes, no, but pretty close.
One thing to keep in mind is that the RTs tend to have a fairly long shift lever throw and one way I have found to get clean smooth shifts is to get a boot with a very stiff toe. A simple steel toe work boot may not be stylish but for $50 on sale it does about as much as all zen shifting techniques, like preloading the shift lever, partial clutch disengagement (single plate dry clutch models) etc.. The human factor can't ignored either. If you have never been confident about executing smooth shifts it is a learned skill and worth the practice time to master.
If the good old days were so damn good, why did we bother to invent modern times?
Most missed bike: Bultaco Sherpa T 326
Page Time: 0.008s Queries: 16 (0.002s) Memory: 2.7606 MB (Peak: 2.9166 MB) Zlib enabled. Server Time: 2018-11-17 01:15:25 UTC
