Bumwah Posted May 1 Share Posted May 1 My 1974 R90/6 at 50 years old needs the throttle cable lubricated. Anybody have a favorite lubricant? I would like to make it easier to accelerate… It seems pretty simple but, it’s been a while. It’s time. Link to comment
Dennis Andress Posted May 1 Share Posted May 1 None. BMW cables have nylon sheathing. Adding a lubricant has always made the problem worse for me. Link to comment
Hosstage Posted May 1 Share Posted May 1 13 minutes ago, Dennis Andress said: None. BMW cables have nylon sheathing. Adding a lubricant has always made the problem worse for me. Even on 50 year old bikes? If they are old school cables with no nylon sheathing, I'm a fan of Tri-Flow lubricant. I know the formula has changed, but I still like it. I sometimes throw a few drops of 3in1 oil in with it. 1 Link to comment
dirtrider Posted May 1 Share Posted May 1 1 hour ago, Bumwah said: My 1974 R90/6 at 50 years old needs the throttle cable lubricated. Anybody have a favorite lubricant? I would like to make it easier to accelerate… It seems pretty simple but, it’s been a while. It’s time. Afternoon Bumwah It kind of depends on your cables, if still has the 1974 cables then I'm not sure if they were Teflon lined or not. If they are not Teflon lined then about any dedicated motorcycle cable lube will work. (do not use motor oil) If it has replacement cables with Teflon liners then do not use conventional petroleum based cable lube. On the Teflon lined cables, you can lubricate them if they start to drag, my personal choice for this is the older (discontinued) Tri-Flow (with Teflon). Unfortunately it is almost impossible to find. If you can find it the old Tri-Flow then it is golden for Teflon lined cable lube. The current Tri-Flow does not contain (Teflon), it might still be OK but I haven't tried it. Never use a petroleum based cable lube on Teflon lined cables. The throttle assembly on the R-90 is unique, it has a gear & chain system in the twist grip housing that requires occasional maintenance, cleaning, & lubrication. Check your PM's (Personal Messages) on this site as I sent you a document (with pictures) of the chain area lube points. Pay attention if you disassemble the drive parts, if you don't line it back up correctly you won't have full throttle travel. Link to comment
Hosstage Posted May 1 Share Posted May 1 You may also want to disassemble and clean the throttle handle. I use a very light coating of grease when I re-assemble it. Don't forget to clean and lightly lube (again, Tri-Flow) the carb linkage as well. Link to comment
taylor1 Posted May 1 Share Posted May 1 Alot of times on an airhead when the throttle gets stiff it is the throttle gear. As Hosstage mentioned, take it apart and give it a good cleaning and you will probably be surprised. 1 Link to comment
Bumwah Posted May 1 Author Share Posted May 1 Thank you everyone… The actual drive gear and chain, throttle cable control is brand new and smooth in operation.( Last Years panic ). Thanks to DR and our forum for getting the correct parts. Back in the day I remember using molybdenum dry slide on cables but never on this bike. I’ll try and find Triflow or something equal to the task Or maybe I’m weaker and it takes more energy to ride? Nah! Can’t be that… I’ll find some lube!. Link to comment
Scotto336 Posted June 25 Share Posted June 25 On 5/1/2024 at 12:32 PM, dirtrider said: Afternoon Bumwah It kind of depends on your cables, if still has the 1974 cables then I'm not sure if they were Teflon lined or not. If they are not Teflon lined then about any dedicated motorcycle cable lube will work. (do not use motor oil) If it has replacement cables with Teflon liners then do not use conventional petroleum based cable lube. On the Teflon lined cables, you can lubricate them if they start to drag, my personal choice for this is the older (discontinued) Tri-Flow (with Teflon). Unfortunately it is almost impossible to find. If you can find it the old Tri-Flow then it is golden for Teflon lined cable lube. The current Tri-Flow does not contain (Teflon), it might still be OK but I haven't tried it. Never use a petroleum based cable lube on Teflon lined cables. The throttle assembly on the R-90 is unique, it has a gear & chain system in the twist grip housing that requires occasional maintenance, cleaning, & lubrication. Check your PM's (Personal Messages) on this site as I sent you a document (with pictures) of the chain area lube points. Pay attention if you disassemble the drive parts, if you don't line it back up correctly you won't have full throttle travel. I know Snowbum has advised against lubing teflon cables with oil in the past, but I believe this was to prevent the lube from being a magnet for debris, not chemical compatibility. Teflon is fine with petroleum based oils and pretty much everything else you might use. It's commonly used in the oil industry https://www.teflon.com/en/industries-and-solutions/industries/energy-oil-gas . If you have a sticky throttle cable set that is routed properly I would recommend replacing the cable(s) as a matter of safety. Link to comment
Paul De Posted July 31 Share Posted July 31 Yup a lube without grease or high viscosity oil is highly recomended. Look for a dry lube that will not gum up or foul with dust and dirt. Back in the day before nylon/Teflon coated cables I used LPS-1 dry lube, and while it does have a super light weight oil carrier for the solid lubricant components it dries out and does not attract dust and dirt. I see that LPS now offers LPS Magnum PTFE dry lube, which might be even better than LPS 1, but the LPS-1 is tried and true dry lube that works great with old school cables. I think somewhere in the bottom of a tool box somewhere I have one of these a now little used wigets It works great with spray lube with the thin applicator tube to push the lube all the way through to the other end. Link to comment
MichiganBob Posted July 31 Share Posted July 31 I'm also a Tri-Flow fan. Used to get it from a locksmith, now from Amazon. 1 Link to comment
