andydavis Posted June 17 Share Posted June 17 I am cleaning up the garage and advertized an oversized Vstream touring windshield on the local CL for $30 (no bites) https://sfbay.craigslist.org/eby/mpo/d/albany-vstream-large-touring-screen-for/7757455355.html. I think this windshield was designed mostly for the comfort of the passenger; however, it is worse at high speeds for a solo rider. Since it seems to have no value, I am tempted to cut it down to a more reasonable size. The screen is polycarbonate, which is made clear by covering with a thin film (I know from previous failure). I hesitate to f'ck it up just as an experiment. I have the correct blade for my jigsaw and believe I can successfully polish the cut edge, but I would be willing to follow more sage advice from the forum. Link to comment
John Ranalletta Posted June 17 Share Posted June 17 I shortened a windscreen years ago. Apply tape to the surface to prevent the base from scratching the surface. Draw your cut line on the tape and cut with a super fine blade. Use a sponge sanding block wrapped with progressively fine sand paper grits up to a 2500 polishing grit. Worked for me. Good luck. Post pictures. Link to comment
andydavis Posted June 18 Author Share Posted June 18 thanks, but moot point now...a guy from Oakland on a 2009 RT just picked it up. Link to comment
