Bjhunter Posted June 27 Share Posted June 27 I recently noticed my abd light flashing and my rear brake get hard. I will only be able to use the hand brakes. But when it cools off, no ABS light and the rear brakes start working. Link to comment
dirtrider Posted June 27 Share Posted June 27 3 hours ago, Bjhunter said: I recently noticed my abd light flashing and my rear brake get hard. I will only be able to use the hand brakes. But when it cools off, no ABS light and the rear brakes start working. Morning Bjhunter We need more information on your problem. Like how far do you ride before the problem appears? Can you hear the rear brake servo running without having the hand lever pulled or rear brake pedal depressed. There are a number on things that can cause your problem from the rear brake pedal & rear switch not adjusted properly to the rear servo running all the time until it overheats then shuts down. Could even be an internal ABS module pressure switch failure. You might have to get a GS-911 on that motorcycle to see what the brake failure faults are trapped. Link to comment
Bjhunter Posted June 27 Author Share Posted June 27 Thanks so much for your response. The light usually come on after about 25 minutes ride. I haven't paid attention to the brake servo running without stepping on the rear brake. But I have been riding through water recently though Link to comment
