Bill Cats Posted June 28 Share Posted June 28 Leaking fork seal on 1994 R1100RSL - looking for parts source and tools / parts list, tools list - it appears that i will need some rather large sockets,,, does the triple have to be dismantled ? fluid type and quantity ? how to get fork tubes apart? source for fork seals.? Thank You.. Link to comment
Michaelr11 Posted June 29 Share Posted June 29 I don’t know the difference in the procedure between the RT and RS. I have done this more than once on my RT. It is a relatively easy procedure. There are at least two videos on YT that show how. Chris Harris does it from above on an RT. Kurt does it from below on a K LT, but the forks are the same. From above, you release the nut holding the top of the fork tube, you should need a 22mm open wrench to hold the tube. Once the nut is off, the tube drops down and then it is shifted to the side and lifted out. You then have access to the fork dust cover and seal on top of the leg. You can remove them with a lever carefully, but a seal remover is cheap and works better.. I have bought the new seals and dust covers from All Balls Racing. The fork oil is there just for lubrication, you don’t necessarily have to change it. 470 ml each leg. It doesn’t provide any damping or suspension component, so any light oil, fork oil, is fine. 2 Link to comment
Jim Moore Posted July 1 Share Posted July 1 On 6/28/2024 at 8:12 PM, Michaelr11 said: a seal remover is cheap and works better.. I've always just jammed a big screwdriver under the seal and popped it out, but I LOVE a new tool. What do you use as a seal remover? Can you post a link? Link to comment
Michaelr11 Posted July 1 Share Posted July 1 2 hours ago, Jim Moore said: Can you post a link? A search for Seal Puller will show lots of choices. Here’s one, https://www.amazon.com/dp/B0D12BCSR7/ref=sspa_dk_hqp_detail_aax_0?psc=1&sp_csd=d2lkZ2V0TmFtZT1zcF9ocXBfc2hhcmVk 1 Link to comment
Jim Moore Posted July 6 Share Posted July 6 On 7/1/2024 at 9:06 AM, Michaelr11 said: A search for Seal Puller will show lots of choices. Here’s one, https://www.amazon.com/dp/B0D12BCSR7/ref=sspa_dk_hqp_detail_aax_0?psc=1&sp_csd=d2lkZ2V0TmFtZT1zcF9ocXBfc2hhcmVk Ordered! Thanks. Link to comment
