TEDZ Posted July 5 Share Posted July 5 I have a 2013 R1200RT with a bad Multifunction Display. It was fine Tuesday, but today on start up the lower half flickered. After stopping for lunch, the lower half was out. Only about 12,000 miles on the bike, it's stored in a garage and kept on a battery tender. One year old battery. I noticed a bad harness connection in the faring. Maybe related, but I don't think so. Am I looking at a new Instrument Cluster? The song? It's A Bad Thing. Link to comment
dirtrider Posted July 5 Share Posted July 5 49 minutes ago, TEDZ said: I have a 2013 R1200RT with a bad Multifunction Display. It was fine Tuesday, but today on start up the lower half flickered. After stopping for lunch, the lower half was out. Only about 12,000 miles on the bike, it's stored in a garage and kept on a battery tender. One year old battery. I noticed a bad harness connection in the faring. Maybe related, but I don't think so. Am I looking at a new Instrument Cluster? The song? It's A Bad Thing. Afternoon TEDZ It does look like yours is failing but you can at least try a few things. If you have any other added electronics, added non-oem headlight, or added-on electrical devices on that motorcycle then try disconnecting those as a test. You might also try a half-hour battery disconnect as a test. You might also try disconnecting then re-connecting the dash connector just to see if reseating the connector helps. 1 Link to comment
TEDZ Posted July 19 Author Share Posted July 19 Did the battery disconnect for about an hour and it was still bad. The next day, still bad, with no action on my part. Day 3, it worked just fine, and it's still fine. Link to comment
TEDZ Posted July 20 Author Share Posted July 20 Well crap, this morning the lower half of the display flickered at start up and went blank about 20 miles down the road. Link to comment
dirtrider Posted July 20 Share Posted July 20 5 minutes ago, TEDZ said: Well crap, this morning the lower half of the display flickered at start up and went blank about 20 miles down the road. Morning TEDZ The next thing to try is a bit more difficult, you will probably have to try unplugging the dash connector then plugging it back in. If you have access to some contact cleaner then you might also try that on the connector terminals. Link to comment
