abush357 Posted 12 hours ago Share Posted 12 hours ago My 2012 RT has started making a rattling noise when I close the throttle and the rpm's drop. Doesn't always do it, but it usually does happen when I get home for the day, warm engine. Not there when the engine is cold, and sometimes it's not there after warm-up. Service light is on because it's time for an oil change (I think). Oil level is half way up the sight glass. Throttle bodies? Cam chain? Link to comment
Rougarou Posted 11 hours ago Share Posted 11 hours ago Does the rattle go away when you pull the clutch in? Link to comment
abush357 Posted 9 hours ago Author Share Posted 9 hours ago 2 hours ago, Rougarou said: Does the rattle go away when you pull the clutch in? In the video I posted the bike is in neutral clutch out, but I'm pretty sure it is unaffected by the clutch. I double check on my next ride. Link to comment
Rougarou Posted 8 hours ago Share Posted 8 hours ago My '06 RT in neutral cycling the clutch. Link to comment
abush357 Posted 8 hours ago Author Share Posted 8 hours ago that's not the sound mine is making, mine sounds like chain or valve noise to me. Yours sounds like a distinct tapping. It's not very apparent in the video when I play it through speakers (in my video), but it is really easy to hear when I play the video on my phone. Does yours sound like that hot and cold? Link to comment
Rougarou Posted 8 hours ago Share Posted 8 hours ago 15 minutes ago, abush357 said: that's not the sound mine is making, mine sounds like chain or valve noise to me. Yours sounds like a distinct tapping. It's not very apparent in the video when I play it through speakers (in my video), but it is really easy to hear when I play the video on my phone. Does yours sound like that hot and cold? It did sound like that. this was at 60k miles or so. I've had the tranny replaced and now back to a normal rattle for the past 96k. At least cycle the clutch while in neutral, should rule out the tranny and put the focus on the engine. Link to comment
