jjpen Posted yesterday at 08:52 PM Share Posted yesterday at 08:52 PM I know it has been talked to death but I am having trouble finding the specified gear oil for the transmission. Would it hurt to use 80w140 to hopefully help it shift a bit quieter and would it be ok to use oil with anti slip additive? Thanks Link to comment
dirtrider Posted yesterday at 08:57 PM Share Posted yesterday at 08:57 PM 3 minutes ago, jjpen said: I know it has been talked to death but I am having trouble finding the specified gear oil for the transmission. Would it hurt to use 80w140 to hopefully help it shift a bit quieter and would it be ok to use oil with anti slip additive? Thanks Evening jjpen That is pretty thick, you might be better off with 75w90 gear oil. As for limited slip additive in the gear oil, some do it without issues but personally I don't recommend it if you can avoid it. Link to comment
Dave_in_TX Posted 23 hours ago Share Posted 23 hours ago 1 hour ago, dirtrider said: Evening jjpen That is pretty thick, you might be better off with 75w90 gear oil. As for limited slip additive in the gear oil, some do it without issues but personally I don't recommend it if you can avoid it. Around where I live, 75w90 is ,much easier to find then 80w140 Link to comment
jjpen Posted 19 hours ago Author Share Posted 19 hours ago Does the oil need to be gl5 and how about full synthetic? Link to comment
dirtrider Posted 12 hours ago Share Posted 12 hours ago 7 hours ago, jjpen said: Does the oil need to be gl5 and how about full synthetic? Morning jjpen BMW's original recommendation was Castrol SAF-XO. Castrol SAF-XO is a 75w90 GL-5 gear oil. Link to comment
