BluegrassPicker Posted May 4, 2008 Share Posted May 4, 2008 If you have bungee buddies, what do you think of them? I have them, know where I mount them, but am nervous to drill the holes. It looks like they my pull up on the bags some when in use - anyone have positive or negative comments before I commit? Link to comment
tomk99r11 Posted May 4, 2008 Share Posted May 4, 2008 I have 2 on each saddle bag. Put large diameter washers on the inside of the bag with a little silicone sealant on the buddie and on the washer. Never leaked in 5 yrs. As for any other problem, you don't need to put too much pull on any bungee cord to have them hold, although I have put some pretty good stretch on the cords without any apparent warpage of the case. I wouldn't worry about it. Link to comment
skinny_tom (aka boney) Posted May 4, 2008 Share Posted May 4, 2008 I've got a couple on each bag. I tie all my "detail" stuff to them with a bungee net. It's a pretty big load, and I've not had any problems. Link to comment
ShovelStrokeEd Posted May 4, 2008 Share Posted May 4, 2008 I don't use bungees, period. Just don't trust 'em. I do use Rok straps and Kathy's straps to fasten things to my bike outside of the bags. My Honda has a couple of pretty strong tie points available that make this easy but, even on the BMW, passenger peg mounts, the luggage mounts (particularly the rack for the top box) all provide places to loop a strap. I recant, Sock Monkey gets tied down with a bungee (no hooks). Link to comment
awagnon Posted May 5, 2008 Share Posted May 5, 2008 I tried Bungee Buddies but didn't like them because they were too small for straps. ( I think actual bungees are unsafe. ) Now I use stainless steel deck loops sold online by a marine supply company. They have a 1 1/4 inch wide by 1/4 inch space which is perfect for my 1 inch straps. Also, hold them on with SS screws. Link to comment
flyingreg Posted May 5, 2008 Share Posted May 5, 2008 I have used bungee buddies for about four years now, they work fine, no issues noted with the bags. The eye is smallish and can be a pain for straps, hooks are OK. Marine eye deck bolts could be a good alternative. Here is but one example, LINKY Link to comment
Sailorlite Posted May 5, 2008 Share Posted May 5, 2008 For actual straps, rather than bungee cords or hooks, marine suppliers sell "eye straps" of various sizes and materials, and hardware stores seem to call them "footman loops". They all have two fasteners, one at each end, which makes installing them more of a project than the Bungee Buddies with single fasteners. Link to comment
pclarin Posted May 5, 2008 Share Posted May 5, 2008 I've bought a set or two but haven't installed them. Not really sure where to do so. Have never seen them used. So, I'm no help to this conversation.... Link to comment
beemerFROG Posted May 5, 2008 Share Posted May 5, 2008 Have had them on the sides of my top case for a couple of years and NEVER a leak! Yes the hole is a little small, but some nylon strapping with quick disconects (Ace Hardware) loops through it and makes a world of difference. Makes holding a case of beer a breeze! Link to comment
Sidmariner Posted May 5, 2008 Share Posted May 5, 2008 I have three on each side case and six on the top case. Mine are backed by very large fender washers, which help to distribute the stress. They are fantastic accessories and accommodate a wide variety of lashing systems including rope, bungies or bungy nets. It's amazing what you can strap to your bike when you've got these tie-down points. Link to comment
pclarin Posted May 5, 2008 Share Posted May 5, 2008 I have three on each side case and six on the top case. Mine are backed by very large fender washers, which help to distribute the stress. They are fantastic accessories and accommodate a wide variety of lashing systems including rope, bungies or bungy nets. It's amazing what you can strap to your bike when you've got these tie-down points.     I like it! Any chance of some close ups. I'll use the shots to place mine.   Link to comment
Delboy Posted May 5, 2008 Share Posted May 5, 2008 I had some brought over by a friend and i use them with a cargo net.I mounted two on each side case( 1front 1 rear ).Excellent for carrying the tent and other stuff. Link to comment
ItsABeemur Posted May 5, 2008 Share Posted May 5, 2008 I own a t-shrit printing comapny and attempt to ride my 1150rt every day to work. We deliver in the local area for free and I find myself riding across town at the end of the day with a large box of t-shrits strapped to the bungie buddies and wedged between the top case and my driver backrest. They have never failed! Link to comment
JDog Posted May 5, 2008 Share Posted May 5, 2008 Ditto on the BB's. If I have need for larger straps, I find that the hand holds on either side work well and are secure. I mounted mine on the side bags, at the front and rear inner corners. John Link to comment
eddd Posted May 5, 2008 Share Posted May 5, 2008 I find that they are very useful. I currently have 8 mounted on my bike and bags. Here you can see one on the front of the side bag, front of the rear case, one on the body work aft of the rear seat, and one on the bottom of the rear case. This is replicated on the other side. The latest ones I added were those at bottom of the rear case. I use this as an anchor point to hang / lock my helmet and or jacket. (Thanks, lawman, I modified your idea.) Bungee Buddies allow me to carry very large loads. You do need to be careful to purchase bungees that have hooks that will fit. Speaking of bungees, there is a great variety now available, Link to comment
Nevets Posted May 5, 2008 Share Posted May 5, 2008 Here is another type I just ran across. Looks like overkill, but I saw it in the Competition Accessories catalog. The add says "Put a swiveling tie-down ring wherever you need one, remove it when you don't need it. Leaves a low-profile mounting base when not in use. Ring is 1 1/8" in diameter. 11.95 Each. @ Competition Accessories here.. Appears to be made by a company called Ancra. May be P/N 40340-27, with a couple parts added. Link to comment
BluegrassPicker Posted May 6, 2008 Author Share Posted May 6, 2008 Thanks to all for the ideas and photos.... Link to comment
awagnon Posted May 6, 2008 Share Posted May 6, 2008 Here are some not too good pictures of the stainless steel deck straps used on my RT and R bikes. I have one BB on the R bike. The black dot under the straps on the RT (first picture) is where I had Bungee Buddies and removed them. The hole was plugged. Link to comment
elkroeger Posted May 6, 2008 Share Posted May 6, 2008 I have the "stainless steel strap loop" available here: http://www.seattlefabrics.com/metal.html get some stainless screws, fender washers and some nylock nuts to attach them. I like the fact that there are two screws for each lash point, rather than one for the bungee buddy. Whatever you put on there, make a point of doing a nice job and get them lined up square. Otherwise it'll look like crap. I won't buy your used bike with the wonky strap loops no matter how cheap it is. Also do not attach the loops to the lids, or you'll have to detach a bunch of stuff to get into your side bags. Link to comment
pclarin Posted May 6, 2008 Share Posted May 6, 2008 Hey thanks for the close ups. That gives me ammo. Link to comment
Vermont Posted May 13, 2008 Share Posted May 13, 2008 Hello forum, So how big of a hole do you need to drill when installing the bungee buddies? Does water get in to the bags once they are installed? Thanks. Link to comment
Jerry Johnston Posted May 13, 2008 Share Posted May 13, 2008 Hello forum, So how big of a hole do you need to drill when installing the bungee buddies? Does water get in to the bags once they are installed? Thanks. No larger than the bolt you screw into the buggee-buddy. If you use a rubber washer under the bb or sealant, you won't have any leaks. Link to comment
Steve R1200RT Posted June 30, 2012 Share Posted June 30, 2012 I have three on each side case and six on the top case. Mine are backed by very large fender washers, which help to distribute the stress. I would like to install 2 bungee buddys on each side of my 49L top case on my '07 R1200RT. Looking at the comments on this issue, I don't think it's advisable to disassemble the lid of the top case. (double-sided tape and all that). To install yours on your top case, did you do NO disassembly, but simply drill through both inner and outer shell, then use fender washers that contact the inside of the interior shell? If so, how did you know where to avoid the metal clasps that are on the lid? Thanks! Steve '07 R1200RT Link to comment
Quinn Posted June 30, 2012 Share Posted June 30, 2012 I had to grind down one side of the fender washer to get a flat fit on one of my side cases. Sealed under to outside part with RTV; no leak. ----- Link to comment
Peter Parts Posted June 30, 2012 Share Posted June 30, 2012 +1 for nyloc nuts... DAMHIK someday I'll have a "3D printer" and make incredible bits and pieces (instead of making duplicate fiberglass bag lids with plaster molds) Ben Link to comment
Kathy R Posted June 30, 2012 Share Posted June 30, 2012 If you have bungee buddies, what do you think of them? I have them, know where I mount them, but am nervous to drill the holes. It looks like they my pull up on the bags some when in use - anyone have positive or negative comments before I commit? BTDT They were great. I put two on the top case of my RT and 2 each on the top of the side cases. That gave me plenty of options for securing items to the topcase and pillion seat. You can buy a flat plug at any hardware store to fill in the hole if you later take off the BBs. I've got a bag of them ready for the next bike that needs them. Link to comment
Jerry Johnston Posted July 1, 2012 Share Posted July 1, 2012 I don't suppose I can edit something I posted in 2008 but I'll add to it. You can get bungie buddies at any wrecking yard from the roof rack on manty station wagons and RVs for $1 or less. I have 4 on my trunk with a cargo net and have used it to tie down my rain coat when not wearing it. Link to comment
awagnon Posted July 1, 2012 Share Posted July 1, 2012 I had Bungee Buddies on my 2002 RT and didn't like them. I found it difficult to pass a 1" tie down strap through them. I ended up plugging the hole and mounting 1" stainless steel lashing loops from a boating supply. I also used stainless screws, nuts, and washers. If find them much more useful, but not as attractive. Link to comment
moshe_levy Posted July 1, 2012 Share Posted July 1, 2012 I had bungee buddies on the 2004 RT because installing them was a snap. If anyone's followed the thread on installation on the Hexhead bags you will see why some are hesitant. And besides, carrying a truly large load with bungees is not ideal - I tested a product for MCN called "Piggyback Straps" about 5 years ago - see http://www.mklsportster.com/Articles/mcnpiggyback.pdf - and they are a FAR preferrable alternative. There are similar products with other names though I have no experience with those. You can see the bungee buddies in the pics of that article, but after trying straps the bungees got little to no use. -MKL Link to comment
DiggerJim Posted July 2, 2012 Share Posted July 2, 2012 I tested a product for MCN called "Piggyback Straps" about 5 years ago - see http://www.mklsportster.com/Articles/mcnpiggyback.pdf - and they are a FAR preferrable alternative. There are similar products with other names though I have no experience with those. Stopped using bungies myself when I got some Rok Straps (lots of folks carry them including Amazon )at the BMW MOA Nationals. They work 100% better and zero chance of having one snap back and bite you with a wayward hook when you're stretching over a load. Link to comment
