MikeKing Posted May 1, 2009 Share Posted May 1, 2009 How do I drain the transmission oil. From the looks of the fill and drain holes, the oil would run down into where it shouldn't. Is there a special funnel you attach to catch the draining fluid? Thx Mike San Francisco Link to comment
Ken H. Posted May 1, 2009 Share Posted May 1, 2009 Make a makeshift funnel out of a paper towel roll center. Or out of foil. But no matter what you do you'll likely mess some. It's just part of the "dance." Link to comment
John844 Posted May 1, 2009 Share Posted May 1, 2009 I do 3 things. Take a little foil and make a liner/cover for the exhaust(to keep any spills off it). use a piece of cardboard to make a drain tube (like Ken said). Put a small block under the left leg of the center stand to make the bike lean a little bit. Link to comment
T__ Posted May 1, 2009 Share Posted May 1, 2009 Mike, I never cover anything & never make a mess.. First off just take an old milk jug or water jug & make a drain trough as shown in picture.. Then either park the bike on a slight incline or place a piece of ½” thick plywood under the off side center stand foot to tilt the bike slightly in the direction of the trans drain plug.. That way ALL trans oil drains out & it also makes sure everything runs away from the bike.. I have found the drain trough works better than a tube as you don’t have to run your wrench extension & socket up through the tube with the oil.. The trough allows straight on access to the drain plug so you can see what you are doing.. Twisty Link to comment
MikeKing Posted May 1, 2009 Author Share Posted May 1, 2009 That's a nice pieces Twisty. Thanks! Link to comment
Beembish Posted May 1, 2009 Share Posted May 1, 2009 a piece of vinyl siding about 2" wide and a foot long works well, too. Any plastic tube cut length wise. Link to comment
