BarOne Posted May 2, 2009 Share Posted May 2, 2009 In the middle of a final drive fluid change -- need to know how much fluid is needed for an 05 R1200RT. Thanks Link to comment
Missouri Bob Posted May 2, 2009 Share Posted May 2, 2009 220 cc + maybe 10 cc more to compensate for that which doesn't make it into the drive. You ARE using 75w90, aren't you? Bob Link to comment
marcopolo Posted May 2, 2009 Share Posted May 2, 2009 I have a service bulletin in front of me for the GS final drive (same as the RT). For an oil change it calls for .23 litres. And yes, it's 75W90 synthetic GL5 gear oil that BMW specifies. Link to comment
rglassma Posted May 2, 2009 Share Posted May 2, 2009 In the middle of a final drive fluid change -- need to know how much fluid is needed for an 05 R1200RT. Thanks According to the maintenance video, approx. 8 oz ... I put a little more in to compensate for waste or for that which that doesn't get in the speed sensor hole. The thing is, since the speed sensor hole is up high, it isn't like other bikes where you fill it to the top of the threads. You actually can't see it. So, you have to take it on faith. I just did mine and put about 9 oz in. It didn't blow up yet. Make sure you lube the splines on the final drive before you put it back together. Good luck Link to comment
marcopolo Posted May 2, 2009 Share Posted May 2, 2009 .23 litres is 7.8 US fluid ounces. I'd just measure the fluid in ml. Link to comment
BarOne Posted May 2, 2009 Author Share Posted May 2, 2009 Thanks guys -- got it done and so far no leaks. This board rocks. Link to comment
Don_Eilenberger Posted May 3, 2009 Share Posted May 3, 2009 Given the design of the rear drive - I suspect +/- 20cc's or so will make absolutely no difference in performance or drive life. The oil isn't sitting in the bottom of the housing once the bike gets moving - it's being churned around inside and carried up on the crown gear. I found that RideOn (tire-sealant) squeeze bottles are 8Oz, which is perfect since they come with a nozzle/hose fitting. Squeezing the oil into the rear drive - while a tad tedious (took about 10 minutes) wasn't rocket science. Link to comment
markgoodrich Posted May 3, 2009 Share Posted May 3, 2009 Two suggestions which might make it easier next time. Go to a beauty supply store and hunt around until you find a plastic bottle measured in ml, with a long spout. Volume problem solved. Put most of the fluid in the "drain" hole until it begins to try to run out, then the last bit through the sensor hole. Cuts out nine of Don's ten minutes. Link to comment
Mister Tee Posted May 3, 2009 Share Posted May 3, 2009 I use a 50 cc horse syringe and a short length of poly tubing (kind you would use in a fish tank.) Works great, and you don't have to separately measure anything out. Link to comment
