scout6 Posted June 30, 2009 Share Posted June 30, 2009 After the second valve failure in less than 3000 miles of riding, I did some digging. There is a large valve stem recall (as mentioned in the AMA a few months back). It lists lots of valves that are marked with TR413 - TR415. My valves were 412's, but both failed above the flange in the body, below the threading. The first one caused a few hundred in associated travel costs and a bent rim. The second cost a new tire at premium mark up last Saturday. The way to test the is by pushing on them to lean them over, like you are going to fill them in tight location. I recommend not doing this away from the dealer, unless you are changing your own tires. I am going to find the metal ones and do any required mods to get them on my R1150RT Wheels before my next trip. Link to comment
Lawman Posted June 30, 2009 Share Posted June 30, 2009 Just ran out in the garage to check my two spares..They are both TR 412.. Exactly why I'm hesitant to replace a perfectly working stem.. Link to comment
scout6 Posted June 30, 2009 Author Share Posted June 30, 2009 I thought mine were working fine, until I was checking the air pressure. That is when the first one failed, and the second one started leaking slowly after a pressure check. Link to comment
Lawman Posted June 30, 2009 Share Posted June 30, 2009 http://blogs.consumerreports.org/safety/2008/06/valve-stem-reca.html My TR 412's are also stamped "made in Germany". The defective ones appear to be made in China..I'd be interested in knowing where your TR 412's that failed were made.. Link to comment
Boffin Posted June 30, 2009 Share Posted June 30, 2009 Just ran out in the garage to check my two spares..They are both TR 412.. Exactly why I'm hesitant to replace a perfectly working stem.. TR412 is the size. There was a batch of crappy Chinese made valve stems of all sizes that were on the market a while back. My TR412s came from Germany in a bag of 100. Andy Edit: Just read your second post: The German valves are decent quality and have to be approved by the TUV (a strict vehicular standards organisation). Link to comment
Lawman Posted June 30, 2009 Share Posted June 30, 2009 Just ran out in the garage to check my two spares..They are both TR 412.. Exactly why I'm hesitant to replace a perfectly working stem.. TR412 is the size. There was a batch of crappy Chinese made valve stems of all sizes that were on the market a while back. My TR412s came from Germany in a bag of 100. Andy Edit: Just read your second post: The German valves are decent quality and have to be approved by the TUV (a strict vehicular standards organisation). Great! thanks.. Link to comment
scout6 Posted June 30, 2009 Author Share Posted June 30, 2009 I am guessing since mine do not say where they were built, that they were probably made in china. Link to comment
Redbrick Posted June 30, 2009 Share Posted June 30, 2009 http://blogs.consumerreports.org/safety/2008/06/valve-stem-reca.html My TR 412's are also stamped "made in Germany". The defective ones appear to be made in China..I'd be interested in knowing where your TR 412's that failed were made.. My spare is the same; TR 412 and "Made in Germany"....I only buy them from the BMW dealer so it's assumed that they are all from Germany but that's obviously only an assumption....Just replaced tires on Kathy's 1150 and my 12RT along with new stems...Think I'll call the dealer and see what they say about manufacturing origin... Just did that and they only buy the German one's as you'd expect.... Thanks Scout6 for the heads up..... Link to comment
scout6 Posted July 1, 2009 Author Share Posted July 1, 2009 Bad news. Mine were installed by the dealer, and now that I have the old tri-focals on, those dots resolved into "Made in Germany". Going to change over to the metal stems. Link to comment
