chadwick Posted July 26, 2009 Share Posted July 26, 2009 Hello all, My heat tape on the underside of the saddle bag near my exhaust peeled off the other day. Does anyone have a suggestion on a suitable aftermarket replacement tape and source? Thanks. Link to comment
Selden Posted July 26, 2009 Share Posted July 26, 2009 Aerostich.com sells . Clean the underside of the case thoroughly (91% rubbing alcohol works nicely). I made this replacement about 18 months ago, and it's holding up well. Heat Tiles Link to comment
T__ Posted July 26, 2009 Share Posted July 26, 2009 chadwick, whatever you put on there watch what you use to glue it on with.. We have had a few fires in our test cars due to gluing a 400°f heat baffle on using a glue rated for 200°f.. I really don’t think there is much heat on that lower case corner due to air flow across the bottom of the case.. Just more of less a heads-up on the glue thing. Twisty Link to comment
Selden Posted July 27, 2009 Share Posted July 27, 2009 Pasting the Aerostich URL created a double http, so the link doesn't work, and I can't edit the post. The correct link to Aerostich heat tiles is: http://www.aerostich.com/catalog/US/Heat-Tile-Kits-p-19089.html Link to comment
chadwick Posted July 27, 2009 Author Share Posted July 27, 2009 Thanks guys for the help...I'll give Aerostich a try! Link to comment
