taters Posted August 3, 2009 Share Posted August 3, 2009 is it true that if one buys a new bmw and gets the esa option then one can't get aftermarket shocks?eg ohlins, wilburs Link to comment
smiller Posted August 3, 2009 Share Posted August 3, 2009 No, stock ESA shocks can be replaced with the aftermarket unit of your choice. Link to comment
Fightingpiper Posted August 3, 2009 Share Posted August 3, 2009 you just wont be able to use the ESA with aftermarket shocks except Works. Link to comment
bobbybob Posted August 3, 2009 Share Posted August 3, 2009 is it true that if one buys a new bmw and gets the esa option then one can't get aftermarket shocks?eg ohlins, wilburs Just curious--is this some more typical dealer mis-information? Link to comment
marcopolo Posted August 4, 2009 Share Posted August 4, 2009 I just replaced the ESA shocks on my '06 RT with a set of Ohlins a couple of weeks ago. Link to comment
Bheckel169 Posted August 4, 2009 Share Posted August 4, 2009 Mark, I'm curious. What didn't you like about the standard ESA on your RT? What were you trying to achieve by replacing with Ohlins? Have you found them to be better? Was this for you, your passenger, both? Curious. Bruce Link to comment
JMR Posted August 4, 2009 Share Posted August 4, 2009 I just replaced the ESA shocks on my '06 RT with a set of Ohlins a couple of weeks ago. And..?? (inquiring minds want to know) Link to comment
Mudman Posted August 4, 2009 Share Posted August 4, 2009 I just installed Ohlins on my 2006 RT with ESA. I have to say I liked the ESA system but the shocks were very worn at 42000 miles. I could have gone with replacement ESA factory shocks but the price is prohibitive and they are not rebuildable. If the factory shocks were rebuildable I would have kept them. Believe me, I tried several shops to find out if they could be rebuilt, no dice. No parts are availible for the job. Having said all of this I am truely delighted with the Ohlins. I ordered mine from Dan Kyle Racing and the support has been great. They ordered the correct springs for my riding weight and the Dynamic Sag measurements were spot on as delivered. Damping was very close and required no adjustment in the front and 1 click firmer on the rear. I unplugged the ESA connections and wrapped the bike connectors in small zip locks should the future owner want to go back to this system. Overall I have found the Ohlins a major upgrade in handling and comfort. Both Ohlins can be rebuilt for about $225.00 by Kyle Racing. According to Kyle this should be done around 30000 miles. I am happy with this upgrade. Link to comment
tallman Posted August 4, 2009 Share Posted August 4, 2009 is it true that if one buys a new bmw and gets the esa option then one can't get aftermarket shocks?eg ohlins, wilburs Just curious--is this some more typical dealer mis-information? No. But it is a typical post from someone. Hope it is cheaper than therapy. Link to comment
marcopolo Posted August 4, 2009 Share Posted August 4, 2009 Mark, I'm curious. What didn't you like about the standard ESA on your RT? What were you trying to achieve by replacing with Ohlins? Have you found them to be better? Was this for you, your passenger, both? Curious. Bruce It was fairly simple. While I liked the convenience of ESA, the price for replacement OEM ESA shocks was outrageous. The rear alone was $2,000 USD. You could imagine the total for two struts + installation. It was a financial decision for the most part. I got Ohlins at the MOA rally in Tennessee in July. Ohlins USA partnered with one of its dealers (Max Moto of California). Ohlins USA got my and my wife's weight, riding style etc. They then selected the appropriate springs, assembled the shocks and then set the initial adjustments. Max Moto then installed them, after which Ohlins USA reps did the final setup with me. Could not have been more convenient and professionally done. Total cost for front and rear shocks (ncluding installation and 9.5% TN sales tax) was $1,720 USD. BTW, my bike had about 50,000 miles. Link to comment
smiller Posted August 4, 2009 Share Posted August 4, 2009 It was fairly simple. While I liked the convenience of ESA, the price for replacement OEM ESA shocks was outrageous. And that's one of the glaring flaws in the ESA concept, in that BMW is equipping their bikes with a common wear item that is prohibitively expensive to replace. And the answer seems to be ESA2, with elements that make it even more difficult to effect any kind of aftermarket rebuild. :smirk: Link to comment
markgoodrich Posted August 4, 2009 Share Posted August 4, 2009 Mark, I'm curious. What didn't you like about the standard ESA on your RT? What were you trying to achieve by replacing with Ohlins? Have you found them to be better? Was this for you, your passenger, both? Curious. Bruce I'm a different Mark, but I'll give you my two cents: the ESA front shock was always a problem, very harsh, essentially way too much high speed compression damping (or the other way around... ). The rear shock was like a pogo stick on some settings, way too soft on other settings. It was hard to hold a line in a corner. I switched to manual aftermarket shocks, and the bike was transformed into a much more precise, fun machine to ride. I don't miss the ESA at all, and I switch back and forth between solo and two up all the time. Just takes a minute to change the rear preload and damping. Front never needs adjusting. MORE IMPORTANT than brand of shock is the setup for the various loads. Link to comment
motoguy128 Posted August 4, 2009 Share Posted August 4, 2009 Does anyone think a good match might be a Ohlins front and a Works or Hyperpro (I think that's the name) in the rear retaining the the system? Since the front doesn't really need much adjustment for different loads. Just a thought. Link to comment
Tapatio Posted August 4, 2009 Share Posted August 4, 2009 I'm going to upgrade my shocks with Works. I currently have 33k on the bike and the shocks are defintely starting to wear out. My reasons: 1) I like the convenience of ESA and would like to keep it. 2) Cheaper than Ohlins. Ohlins are better but I don't think I will notice a significant difference. 3) They are local to me so I can do a drive in appointment. Works BMW ESA shocks Link to comment
smiller Posted August 5, 2009 Share Posted August 5, 2009 Works BMW ESA shocks Nice. That does look like the way to go if Works can get some of the (reported) bugs out of the provisioning process. Be sure to let us know how it works out. Link to comment
Tapatio Posted August 5, 2009 Share Posted August 5, 2009 Works BMW ESA shocks (reported) bugs out of the provisioning process What bugs? My dealer, Irv Seaver, highly recommended these so I figured they worked well. Did I miss some posts on this forum? Link to comment
smiller Posted August 5, 2009 Share Posted August 5, 2009 Well, it seems that Jan hasn't been having the easiest time of it so far. Link to comment
