Starfighter Posted August 17, 2009 Share Posted August 17, 2009 I have a Garmin 2720 Bike powered. I've mounted an Autocom Active 7 smart. For the 2720 I have the power/audio cable. All that remains is the cable from the 2.5mm female on the garmin cable to the phone in on the Autocom. Can I use a generic mono cable 2.5mm to 3.5mm or do I need something special because the GPS is bike powered ? Autocom is not available for questions until 8/19... Link to comment
E30TECH Posted August 17, 2009 Share Posted August 17, 2009 I use a 'generic' cable with 90 degree plugs. I also have it going into a noise filter before it goes into the autocom. Link to comment
Fugu Posted August 17, 2009 Share Posted August 17, 2009 I used a generic cable, 3.5 to 3.5 with a 3.5 to 2.5 adaptor. Both my gps and autocom (active plus) were bike powered. No issues on my install. Link to comment
John Bentall Posted August 17, 2009 Share Posted August 17, 2009 You could try using a generic cable since many people do not seem to have problems with ground loop interference. Personally I would also add the #1285 isolator box between the generic cable and the Autocom. Link to comment
