vizhip Posted August 20, 2009 Share Posted August 20, 2009 Well, the fuel pump is commanded by the motronic based on pulses from the HES. So, that leaves a few possibilities: Fuel-pump relay sticking - the fuel pump is powered via Relay 6. Motronic giving duff output :yikes: HES giving duff input to motronic. My first step would be to swap the horn and fuel pump relay over. If it sticky you will notice.... If you have a scope, check both HES outputs, they should be clean square sided pulses. Andy Curious as to how the fuse 8 slot would act... Thinking about installing a JM CB Radio on the handlebars since the group I ride with uses the CB to communicate... and they all use the JM CBs... Unless someone here knows of a BETTER CB... but... thought about using fuse 8 since it is empty... ))) Link to comment
T__ Posted August 20, 2009 Share Posted August 20, 2009 vizhip, the #8 fuse is a radio fuse so if you have a radio it is already used.. If not it should work fine.. In fact if your bike has the radio pre-wire setup in it the wire coming from fuse #8 should be in the front radio harness connector.. Twisty Link to comment
vizhip Posted August 20, 2009 Author Share Posted August 20, 2009 vizhip, the #8 fuse is a radio fuse so if you have a radio it is already used.. If not it should work fine.. In fact if your bike has the radio pre-wire setup in it the wire coming from fuse #8 should be in the front radio harness connector.. Twisty Excellent... thanks for the fuse info... and yes... the bike has a JEEP radio squeezed into the left front glove box... along with wires that have been disconnected from a previously installed GPS and what appears to be an autocom switch... but the JEEP radio (which doesn't work) is the only gear left behind, so I figured when I pulled off the fairing and added a CB to the bike that I could remove all that excess wiring... Sounds like fuse 8 now has a purpose... Regards - -Bob Link to comment
