Larry Brons Posted September 11, 2009 Share Posted September 11, 2009 Here goes, tail between my legs. I bought a new top case, the big one. It came with the lock insert so it can be keyed to match the ignition. So far so good. Well, I can follow instructions, I inserted it into the cylinder without having it correct and it went in but wouldn't turn, wouldn't unlock, wouldn't come out. The key would go in and out but the barrel wouldn't come out. It was recommended that I take it to a locksmith for removal. I did, he couldn't remove it and offered to drill it out. No problem, buy a new barrel and chalk it up to experience. Problem! When he was drilling it out it spun and broke the key-way inside and now it won't open. The barrel is out but the insides are damaged. BMW says that the sleeve (cylinder) isn't replaceable and the only option is to replace the lower half of the box, $570.00. OUCH! Anybody have any ideas? Link to comment
10ovr Posted September 11, 2009 Share Posted September 11, 2009 You put to many inserts (tumblers) in,,thats why it locked up on you,,Been there,,Done that,,You can take the box apart,,But let me tell you it's a BITCH to put back together,,There are all sorts of parts the just fall apart as you take it apart,But it can be done,, Link to comment
T__ Posted September 11, 2009 Share Posted September 11, 2009 Larry, maybe.. Can you get the key-way out? If so maybe that can be repaired or a part fabricated.. OR,, maybe look into a couple of flip over latches (suitcase like) like the older GoldWings use.. Those (old GoldWing) latches can even be locked.. Twisty Link to comment
perfectswitch Posted September 12, 2009 Share Posted September 12, 2009 I just went through this a month ago. Call me. It will save you time, money, and aggravation. Scott 858-583-2146 Link to comment
Larry Brons Posted September 12, 2009 Author Share Posted September 12, 2009 I'll call you tomorrow, thanks. Link to comment
Larry Brons Posted September 12, 2009 Author Share Posted September 12, 2009 The locksmith drilled the barrel, and the barrel was engaged in the key-way at the time, apparently the torque from the drill broke the plastic kay-way loose. That part is still deep in the bottom of the opening (sleeve) that holds the barrel. Kind of stuck in there right now. Link to comment
AZgman Posted September 12, 2009 Share Posted September 12, 2009 Did the locksmith charge you for breaking the lock? Link to comment
Larry Brons Posted September 12, 2009 Author Share Posted September 12, 2009 They wanted too. For now they offered to wave the $20 charge. I'm curious if I'm the only one who thinks they have some responsibility here. If they couldn't remove the barrel, it seems to me they should have stopped. If this was a car door that got damaged, would they pay to have it fixed? Link to comment
Rphoto Posted September 13, 2009 Share Posted September 13, 2009 Sorry to hear about your problems with the lock -- sounds like there are people on here who can help you straighten it out. Here's my recent experience regarding a box lock: I bought a used 28L top box for my K1300GT and it came with a lock installed, but no key. I did an internet search and found a number of illustrated articles on how to get the lock assembly out and to change the tumblers. Seemed a little complicated for my feeble mind so I printed the instructions and took them to a locksmith. He was able to remove the lock, change the tumblers to match my bike's key and reinstall it for $36. This is quite a bit less than the dealer would have charged me for a new lock assembly and installation (plus the service guy was less than eager to do this, probably because I dared to buy used and not a new case from them). Link to comment
TonyT607 Posted September 18, 2009 Share Posted September 18, 2009 Rob, do you still have the links to those online articles ? I'm in a sort of similar situation. I bought a new (leftover) 2008 K12GT in July but kept the side cases and the 28l top box from my R12ST. When I made the deal on the GT I also bought 3 new cylinders keyed to the new bike. My thought was to simply install those cylinders in the old cases and use them; preserving the nice shiny color coded Blue GT cases (and of course only having to ever carry around a single key). So, to net it out I guess I just need to figure out how to remove the cylinders from the 3 cases for which I DO have the key. I know inserting a new keyed cylinder is straightforward. Ideas/suggestions ? Thanks Link to comment
smiller Posted September 18, 2009 Share Posted September 18, 2009 http://www.ebbo.org/re_keying.php Link to comment
NonComp Posted September 18, 2009 Share Posted September 18, 2009 Seem like at the best of times, these locks are aggravating. My buddy with a 1200RT is always having trouble with his top box. If you happen to close and latch the box with something hanging over the lip, and can be nearly impossible to open them again. Unfortunately, you really can't expect the locksmith to make good on $570 bill for a $20 sale. Link to comment
Rphoto Posted September 20, 2009 Share Posted September 20, 2009 http://www.ebbo.org/re_keying.php Those were exactly the instructions I gave my locksmith. And BTW, my locksmith was a small time guy working out of his home in the middle of nowhere -- but he obviously knew what he was doing. Link to comment
swilson Posted August 26, 2016 Share Posted August 26, 2016 Looks like the old web site that had info on removing the lock cylinder easily is gone. I've put up a youtube video covering the lost info so its still available. Link to comment
Bud Posted August 27, 2016 Share Posted August 27, 2016 You put to many inserts (tumblers) in,,thats why it locked up on you,,Been there,,Done that,,You can take the box apart,,But let me tell you it's a BITCH to put back together,,There are all sorts of parts the just fall apart as you take it apart,But it can be done,, If you put a piece in the #2 slot, it won't turn. DAMHIK Link to comment
Indy Dave Posted August 28, 2016 Share Posted August 28, 2016 Thanks for making and posting that Scott. That looks a bit easier than trying to do the same thing, only from inside the cylinder and drawing the tumbler down (with the key opening vertical)with a pic. I'm guessing this approach won't work with the later model that have more plastic shield? Thanks again! Link to comment
