Caddis Posted September 13, 2009 Share Posted September 13, 2009 I posted this on the oilheads wrenching forum but didn't get any replies. So I thought I would try this forum. I just got some Moto-techniques bar risers for my R1100RT, and with the left riser installed, I can't turn the handlebars completely to the left (don't know about the right yet) because the wiring coming from the left handlebar doesn't have enough slack and gets pulled tight. I clipped one of the cable ties, but it looks like I will have to clip all but the last one (farthest from the handlebars) in order to get enough slack. This doesn't seem like a particularly good idea, but I don't see any other options. Other people must have run into this issue before. Should I just clip the cable ties and not worry about it? Is there some other option here? Thanks Link to comment
Kritou Posted September 13, 2009 Share Posted September 13, 2009 You could try re-routing the wiring loom to the outside of the fork leg. Remove the handlebar to expose and undo the nut at the top of the fork leg - lower said fork leg a couple of inches (the front of the bike will flop over so be prepared) and move the wiring over Link to comment
Caddis Posted September 13, 2009 Author Share Posted September 13, 2009 Kritou, interesting suggestion. I hope I don't have to go quite that far, though. It only needs a little more slack, so I will probably just try clipping a couple more of the cable ties. I was concerned that with the cable ties clipped, the wiring loom would "droop" a lot when I turn the other way, with the possible danger of it catching on something. But I guess I will just try it and see. I was just hoping to get confirmation one way or another from someone who has done this before. There must be tons of folks using these same risers - is nobody else experiencing this issue? Link to comment
Eric S Posted September 13, 2009 Share Posted September 13, 2009 I added risers and while might are snug, they are just long enough to be ok. Link to comment
