Sinman Posted September 18, 2009 Share Posted September 18, 2009 I have a battery trickle charger for a gel cell battery. The charger has a conditioning cycle. Can I use this cycle on a gel cell? Link to comment
T__ Posted September 18, 2009 Share Posted September 18, 2009 Sinman, your question doesn’t sound like what you meant to ask.. If your charger is specifically for a Gel Cell then it should work on a Gel Cell.. If you have doubts just E-Mail or call your charger manufacturer as they have the info you need to be sure.. Twisty Link to comment
Sinman Posted September 18, 2009 Author Share Posted September 18, 2009 No, I didn't make myself clear. The charger is for a gel cell and the trickle charger works fine. The charger is also for other battery types. This charger has a "conditioning cycle" which recovers semi-sulphated batteries. My question is: Can I use this cycle on a gel battery? Link to comment
smiller Posted September 18, 2009 Share Posted September 18, 2009 I would guess that the 'conditioning' cycle means equalization, and you should not perform an equalization process on gell batteries. Link to comment
