Boxerdad Posted September 18, 2009 Share Posted September 18, 2009 Where/how have you mounted the aux tank on your 1100 RT? I'm considering using a passenger seat frame as the base. Link to comment
snod Posted September 18, 2009 Share Posted September 18, 2009 Look here. Ebie has a simple, clean setup on his RT Link to comment
NonComp Posted September 18, 2009 Share Posted September 18, 2009 Simple but, oh my, the asthetics of it... Link to comment
La Chuparosa Posted September 18, 2009 Share Posted September 18, 2009 Hmmm...Personally I don't need any more range. I can easily go 300 miles before my low fuel light comes on as it stands now. The 1150RT will go far longer than my bladder. I suppose you want to be able to ride 500 miles non-stop? Link to comment
NonComp Posted September 18, 2009 Share Posted September 18, 2009 A jerry can would do the job without all the plumbing. Link to comment
DavidEBSmith Posted September 19, 2009 Share Posted September 19, 2009 Simple but, oh my, the asthetics of it... As Louis Sullivan said (sort of), form follows function. Link to comment
chinist Posted September 19, 2009 Share Posted September 19, 2009 By passenger seat frame do you mean the seat pan its self? If so I'm curious as to whether you have found somewhere those could bought as a stand alone part? I'm thinking of a similar mod for a luggage set up.... Link to comment
270 Posted September 22, 2009 Share Posted September 22, 2009 Mine is similar to EB's (Hi EB!!!!)but is built onto a bracket that bolts to the four bolts that sit UNDER the passenger seat. I wouldn't trust the passenger pan. FWIW, a good friend of mine just finished the IBR with a tourtech (?) aluminum fuel cell mounted to the rear luggage rack. Weight is well within what can be safely mounted back there and still gives you the pillion spot for a roll bag or the like. HTH... Link to comment
Tank Posted September 22, 2009 Share Posted September 22, 2009 Hmmm...Personally I don't need any more range. I can easily go 300 miles before my low fuel light comes on as it stands now. The 1150RT will go far longer than my bladder. I suppose you want to be able to ride 500 miles non-stop? Would love to have a 500 mile fuel range.... and just cus I had it doesn't mean I can't stop for uh, whatever... restroom, walkabout, ect. Link to comment
Boxerdad Posted September 22, 2009 Author Share Posted September 22, 2009 Hmmm...Personally I don't need any more range. I can easily go 300 miles before my low fuel light comes on as it stands now. The 1150RT will go far longer than my bladder. I suppose you want to be able to ride 500 miles non-stop? Only 350. IBA says I have to stop at 350. Link to comment
Boxerdad Posted September 22, 2009 Author Share Posted September 22, 2009 By passenger seat frame do you mean the seat pan its self? If so I'm curious as to whether you have found somewhere those could bought as a stand alone part? I'm thinking of a similar mod for a luggage set up.... I'm considering tearing the upholstery off of a passenger seat and using the pan as a base for a platform. That way my aux tank will snap onto the bike and come off with the twist of a key. Link to comment
Technologist Posted September 23, 2009 Share Posted September 23, 2009 Figuring a way to carry and deliver several extra gallons of fuel sounds like an adventure in itself. I would rather hide a gas can or two with stabilizer inside on a frequented route then tug around 3-5 extra gallons of fuel. Link to comment
270 Posted September 23, 2009 Share Posted September 23, 2009 Try this... http://www.tourtank.com/tourtanks.html Again, I'd shy away from the pan idea. It's been done, especially on the RS, but I doubt it'd pass the "wiggle" test from the IBA. Then again...there's no need to worry about that for these purposes. Link to comment
DavidEBSmith Posted September 23, 2009 Share Posted September 23, 2009 Again, I'd shy away from the pan idea. It's been done, especially on the RS, but I doubt it'd pass the "wiggle" test from the IBA. Then again...there's no need to worry about that for these purposes. I never felt that the passenger seat on my bike was held down well enough to support a fuel cell. It's really only attached at the front tab and the latch in the rear, and in curves the aux tank will want to rotate around that axis and there's nothing much to prevent it (as compared to a passenger who has legs wrapped around the sides of the bike). Link to comment
LDHack Posted September 24, 2009 Share Posted September 24, 2009 I doubt it'd pass the "wiggle" test from the IBA. I never felt that the passenger seat on my bike was held down well enough to support a fuel cell. Mine is attached to an extra rear saddle on my RT. I prefer it there vs on the luggage rack. I can use the rear trunk, and more important; the extra fuel weight is not hung over the rear wheel. It passed IBR wiggle test, although I carry a ratchet strap just in case I need to reinforce the attachment for a nit-picky inspector. Link to comment
