MSmith Posted September 20, 2009 Share Posted September 20, 2009 I have a 2005 RT with the radio option. I set the radio bass and treble tone controls to desired settings but after the bike has been off awhile, the radio settings return to the default 0 settings. Is this normal? Link to comment
Kerry in Mpls Posted September 20, 2009 Share Posted September 20, 2009 I just went out to the garage and turned on the radio (actually the CD player) on my '06 RT. The bass is still at +6 and the treble is still at +1. The last time I turned it on before that was probably two weeks ago (I usually use other audio sources). Seems yours is not behaving normally. Link to comment
John Bentall Posted September 20, 2009 Share Posted September 20, 2009 The power supply for the radio memory might not be functioning correctly. Link to comment
FrankBrown Posted September 20, 2009 Share Posted September 20, 2009 I have a 2005 RT with the radio option. I set the radio bass and treble tone controls to desired settings but after the bike has been off awhile, the radio settings return to the default 0 settings. Is this normal? No. Link to comment
MSmith Posted September 21, 2009 Author Share Posted September 21, 2009 Thanks for the sanity check. I haven't modified the radio wiring in any way. I'll check the power inputs. Thanks again. Link to comment
