Perlova Posted November 14, 2009 Share Posted November 14, 2009 Has anyone ever made or purchased jumper cables specific for motorcycles? My wife's battery died recently at a gas station. Would have been nice if I could have jump started her F650 from my R1100. Instead, I had to rid home, get the car and use my automotive cables trying not to short anything out..... Link to comment
Skywagon Posted November 14, 2009 Share Posted November 14, 2009 http://www.aerostich.com/catalogsearch/result/?q=jumper+cables Link to comment
John Bentall Posted November 14, 2009 Share Posted November 14, 2009 Because it is an R1100RT with an inaccessable battery you would be better off with this... and it is too risky to start another bike from the onboard 5 amp accessory socket. http://www.wunderlichamerica.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WA&Product_Code=2024568&Category_Code= I had one of these kits on my 1100RT and it worked beautifully. Link to comment
johnlt Posted November 14, 2009 Share Posted November 14, 2009 I've used the aerostich ones and they work fine. I always carry them. On the 11XX bikes, I just use a screwdriver to reach the positive terminal and connect the jumper to it. Not something I would want to do frequently but it does work. Just need to be carful to touch ground. Some have added a shielded pig-tail to the positive terminal that can be used to attach the jumper to. That would be a better solution. Link to comment
Mike05 Posted November 14, 2009 Share Posted November 14, 2009 Came across this, the UpStart, Inc. Motorcycle Booster Cable product. Made for bike-to-bike and/or car cigarette lighter socket. Seemed pretty flimsy when it arrived but I thought it was better then nothing so it ended up in the Trip Kit. To my surprise, it worked just fine the one occasion I actually used it (bike-to-bike). YMMV Link to comment
Perlova Posted November 14, 2009 Author Share Posted November 14, 2009 Thanks for the tips. I'm thinking of making my own jumper set from unused clips from battery tender parts. I may have to upgrade the cable but #8 should be enough for occasional use. Link to comment
elkroeger Posted November 14, 2009 Share Posted November 14, 2009 I made a set from some lamp cord and smallish alligator clips. Obviously the wire is too thin a gauge to be effective as jumper clables in the classic sense... My intention was to use them as "charging cables", where I would at least have some option, rather than no option at all. They are compact enough that they live on the bike full time. I've been in the boat where my 1100rs was dead and I wanted to jump it from the Mrs' f650cs... Neither battery is accessible enough to do much good. It's almost always easier to push start or bum a jump off a passerby in a car, than dig the battery out of both bikes. Link to comment
