Good_Fixs Posted September 26, 2005 Share Posted September 26, 2005 Hi, Guy's I am trying to replace the alternator belt, but look's like the front shock is right in front of the top center bolt of the alternator,do I need to remove the shock? Thanks for any info or advice Link to comment
Rt4Me Posted September 26, 2005 Share Posted September 26, 2005 No, You do not have to remove the shock. You can get to all bolts. You will have to remove at least 1 side of tupperware and the so called shark fin. Then you are in business. Good luck Link to comment
BMWRich58 Posted September 26, 2005 Share Posted September 26, 2005 and the so called shark fin. ....dat *B* the one on the left (sitting on the bike) then slip'er down n out!!! Link to comment
Good_Fixs Posted September 27, 2005 Author Share Posted September 27, 2005 Hi,Bill! why didn't I think of you, maybe next time I just email you for all my technical question instead. BIG Thanks. Link to comment
RiP Posted October 1, 2005 Share Posted October 1, 2005 and hints on reinstalling the belt? Does it just slip on, or do you have to loosen of an adjuster... Mine just blew out today and I am stuck away from home and my repair manual. Link to comment
TREE Posted October 1, 2005 Share Posted October 1, 2005 Here is the Haynes manual page that may help. http://www.geocities.com/jatojet/belt4.jpg Not too hard to replace, tension is right when you can finger twist the belt 90 degrees. Good luck. Tree Link to comment
TREE Posted October 1, 2005 Share Posted October 1, 2005 Here is more info on replacing belt: http://www.geocities.com/jatojet/belt7.jpg Link to comment
Good_Fixs Posted October 1, 2005 Author Share Posted October 1, 2005 Thank you for your advice. Link to comment
