KDeline Posted January 27, 2010 Share Posted January 27, 2010 This might have been covered before, I thought I read it here. It will do the above and also lose sense of touch so it will not respond. I have pushed my thumb around the screen hard and ran my fingernail between the screen and housing hoping to lossen any small sand or dirt. Seemed to help but not fixed. Anybody else seen this? Link to comment
Ken H. Posted January 28, 2010 Share Posted January 28, 2010 My you do have your share of electronics problems Ken! What kind of electrons are you drinking down there? Link to comment
KDeline Posted January 29, 2010 Author Share Posted January 29, 2010 Since we don't have much of an income anymore, everything is now failing. I may have to get a job. Garmin recommended an update, sadly did not work. Link to comment
malcolmblalock Posted January 29, 2010 Share Posted January 29, 2010 My 2610 did this a couple years ago. Essentially useless when that was going on. Contacted Garmin and they warrantied it to a refurb unit (was still barely in warranty). Replacement worked fine. I've read about the jittery screen in other posts, and the bottom line for almost all of them was pay Garmin or replace the unit. Link to comment
jskene Posted January 29, 2010 Share Posted January 29, 2010 This problem is caused by a particle of dirt that gets sandwiched between the layers. If it's out of warranty, you could take it apart and carefully clean between the outer screen cover and the screen. Link to comment
KDeline Posted January 29, 2010 Author Share Posted January 29, 2010 I may have to try that, it is out of warrentee, I have nothing to lose. Link to comment
