markgoodrich Posted February 7, 2010 Share Posted February 7, 2010 I have a 376c, just changed mounts to the BMW shelf, using the Garmin adjustable mount, which lasted about 50 miles before the entire mount popped off the shelf. The round piece in the photo has a nut underneath which literally exploded through the piece; it's the only thing holding the mount to the base. The cradle is cracked. I've tried JB Weld on the cradle twice, now, and it's not holding. I'm very dubious the round base will hold with JB Weld, either. Anyone have spare parts, or know where I can get them, or have a better, more secure mount option for the x76 series to the BMR shelf? TIA Link to comment
UberXY Posted February 7, 2010 Share Posted February 7, 2010 Touratech. Touratech Garmin Mounts Link to comment
lvnvbiker Posted February 7, 2010 Share Posted February 7, 2010 I have a friend with the TT mount on his KTM 990 ADV and a 376c, we were offroad and he hit the bank of a wash so hard it bent his front rim we shot airborne off the upslope and down into another woop section and it held perfectly. They are TOUGH and also dampen the vibes extending the life of your unit... Link to comment
johnlt Posted February 7, 2010 Share Posted February 7, 2010 Mark, I use the TT mount on a BMR shelf on my RT. works fine and places it near my normal sight line so I really don't have to look down. Link to comment
bobbybob Posted February 7, 2010 Share Posted February 7, 2010 Mark, I use this one for my 478--will fit the 376. The button with the red arrow slides forward to lock the unit into the mount. The mount has holes drilled for the ram ball you see attached. Very secure. And I sandwiched some foam between the ram and the mount and attached the screws loosely so it absorbs some vibes too. Link to comment
markgoodrich Posted February 7, 2010 Author Share Posted February 7, 2010 Mark, I use the TT mount on a BMR shelf on my RT. works fine and places it near my normal sight line so I really don't have to look down. Thanks, John...that's a lot of money just to get the thing mounted. I may end up doing that, but am going to search for a less expensive option. Looks like you have the BMR tilt at $55, plus the TT gizmo. What I really need is a new Garmin marine mount, the one that comes with the x76 units. Link to comment
markgoodrich Posted February 7, 2010 Author Share Posted February 7, 2010 Mark, I use this one for my 478--will fit the 376. The button with the red arrow slides forward to lock the unit into the mount. The mount has holes drilled for the ram ball you see attached. Very secure. And I sandwiched some foam between the ram and the mount and attached the screws loosely so it absorbs some vibes too. Right, Bob, I have (had) that cradle, but it's cracked in two. I need the cradle, which will mount to a new Garmin marine mount (I mean, a used one), or worst case, directly to the BMW tilt mount. Switching to a Cal-Sci shield has gotten really expensive. Link to comment
bobbybob Posted February 7, 2010 Share Posted February 7, 2010 That cradle cracked? You have (had) the one with the locking button? Wow--I use it on my DS bikes as well as the RT and it has held up great. Maybe you had a defective one--it feels like ABS and sturdy as hell. It supports not only my 478 but the GXM30 is mounted on top of the 478, so all that weight. Link to comment
bobbybob Posted February 8, 2010 Share Posted February 8, 2010 This is where I bought my last Garmin Marine mount--$31.99--they had it in stock and good service. http://www.tropicaero.com/10Browse.asp?Category=garmin_surface_mount Link to comment
markgoodrich Posted February 8, 2010 Author Share Posted February 8, 2010 Thanks, Bob. I'm pretty leery about buying another one, but don't see much choice. Link to comment
markgoodrich Posted February 8, 2010 Author Share Posted February 8, 2010 It was cracked when I got it, a gift from a fellow who wasn't using it any more. It's now in two pieces, my attempt to repair it failed. Link to comment
