FLrider Posted February 23, 2010 Share Posted February 23, 2010 I feel like an expectant mother. My seat has been in production since Feb 4 and I can't wait for it to arrive.... Actually, I can wait, it's my rear end that can't wait. Should be here any day and I'll be ready for that nice loooooong ride without monkey butt. Link to comment
johnnash Posted February 23, 2010 Share Posted February 23, 2010 I put a heated RDL on my GS last fall!Could not be happier.Best seat I have ever had under me.You won't even think about your Butt. Link to comment
Beemah Posted February 23, 2010 Share Posted February 23, 2010 FLrider, Which style of the day-long did you order? I have a 2009 Titan Silver RT as well and my Russell Day-Long is on the buid calendar for today. I'd love to hear your impressions of the saddle once you receive it. I'm hoping to speak with the builder before he starts the work as I am a little vertically challenged. Congrats, Don Link to comment
FLrider Posted February 23, 2010 Author Share Posted February 23, 2010 FLrider, Which style of the day-long did you order? I have a 2009 Titan Silver RT as well and my Russell Day-Long is on the build calendar for today. I'd love to hear your impressions of the saddle once you receive it. I'm hoping to speak with the builder before he starts the work as I am a little vertically challenged. Congrats, Don Came in today. I too have an 09 RT. Here's what I've observed so far; 1) The driver seat I sent them was a non heated low seat that I bought from someone on this board. I purchased a low seat because, even though I am 6'1" with a 33" inseam, the regular seat, on the lowest position setting, did not allow me to flat foot it. The stock low seat did. The RDL in the lowest seat position does not allow me to quite flat foot it, but I can get most of my foot down and maintain a sturdy position. 2) I think the seat is well built. Care was taken to add a few more staples to the stress points. However, they should have added binding all around the edges like BMW does. Provides additional strength to the material where the staples enter the material. No big deal though. 3) The hookup for the heated seats is different than what I expected. Again, my driver seat was NOT heated but the rider seat was. For extra $ they converted my driver seat to heated. The connectors on the seat are NOT the same as the stock connectors so the way it works is that the driver seat connects to the rider seat via their own male and female connectors. Then, there is a wire from the low seat that connects to the battery. You can see the wiring harness in the photo. I just zip tied the stock wiring and tucked it away. Not sure if they would have used the stock bmw plugs if I had sent them a heated driver seat. I can't recall what the style was. I wanted one with the least amount of potential pressure points. I think they call this "half moon" or "scalloped" but don't quote me on that. I like the finish. I did not go with leather as I have had many custom leather saddles and they just don't seam to wear as well as the synthetic material. Just a personal preference. I know all the arguments about heat retention etc.,.. I just never found those to be all that accurate. Now all I have to do is get on and ride !!! Will let you know how it goes. They said something about a 500-1000 mile break in. I sure hope I feel a difference or more accurately, I hope I don't feel a thing...and not because I'm numb ! Double Staples around stress points Harness for battery hookup New Heat Switch Location Half Moon ? Scallop ? Don't Recall... Link to comment
cali_beemer Posted February 24, 2010 Share Posted February 24, 2010 1) The driver seat I sent them was a non heated low seat that I bought from someone on this board. I purchased a low seat because, even though I am 6'1" with a 33" inseam, the regular seat, on the lowest position setting, did not allow me to flat foot it. The stock low seat did. My understanding is that the seat pan is the same between the low and high for 1200RT, when getting a custom seat made off an OEM pan, it makes no difference becasue they tear out the original foam. Link to comment
FLrider Posted February 24, 2010 Author Share Posted February 24, 2010 1) The driver seat I sent them was a non heated low seat that I bought from someone on this board. I purchased a low seat because, even though I am 6'1" with a 33" inseam, the regular seat, on the lowest position setting, did not allow me to flat foot it. The stock low seat did. My understanding is that the seat pan is the same between the low and high for 1200RT, when getting a custom seat made off an OEM pan, it makes no difference because they tear out the original foam. Well if the seat pan is the same, then it must be the amount of foam that makes the height difference between stock low and stock standard seats. Having said that, again, pan being the same, there must be some difference between the amount of foam Russell puts on and the amount of foam in the stock low seat because there is a distinct difference in seat height. It's as if I had the standard stock seat, in the low position. Link to comment
Indy Dave Posted February 24, 2010 Share Posted February 24, 2010 The difference in the BMW standard and low seats is the amount of padding. The Russell seat will be higher then the stock seat in the same position - unless you ask Russell to use less padding - which they will do, bur without the comfort guarantee. Link to comment
Fubar Posted February 24, 2010 Share Posted February 24, 2010 My understanding is that the seat pan is the same between the low and high for 1200RT, when getting a custom seat made off an OEM pan, it makes no difference because they tear out the original foam. Well if the seat pan is the same, then it must be the amount of foam that makes the height difference between stock low and stock standard seats. There is probably a difference in the TYPE of foam used in addition to the amount. Looks nice, looking forward to hearing how it feels. Link to comment
flat_twin Posted February 25, 2010 Share Posted February 25, 2010 The stitch pattern you have there is the rectangular pattern, my favorite. Looks great, hope it works where it counts!! Link to comment
loboheritage Posted February 25, 2010 Share Posted February 25, 2010 my Russell is just like yours. I believe the seat is not higher, but the "wings" do not allow you to get your legs as close to the bike as the stock seat does. At least that is the case with mine. I am short of leg and the Russell does make a challenge for me. I am really tip toed with the Russell, but I accept it as worth it for the most comfortable seat I have had on any bike...... Link to comment
Beemah Posted February 25, 2010 Share Posted February 25, 2010 My Russell is being shipped today, I got the half-moon design, I'm a vertically challenged person, but I'm determined to meet the challenges necessary to enjoy the comfort. Link to comment
