94aero Posted April 3, 2010 Share Posted April 3, 2010 My Kisan SignalMinder has started having a mind of its own. It just flashes hazard. Can not clear. I put the old flasher back in and flashers and cancel work normally. Is this time for a new one? Has this happend to someone else? Any ideas of where to check? Link to comment
KER Posted April 4, 2010 Share Posted April 4, 2010 I started having issues with mine a while ago. It would randomly not cancel the turn signal, it was pause momentarily when you hit the cancel button but would continue after it was released. I removed it before it got to bad and installed the standard relay. Mine came with the bike when I purchased it used, but I didnt care for it that much anyways so I swapped it with another bike. Link to comment
TonyS Posted April 4, 2010 Share Posted April 4, 2010 Try and reset to whatever timeout you initially used. Mine had stopped working, but I now suspect was simply reset somehow (low battery and a voltage drop on startup perhaps) to the off position. Once reset, several months ago, all is once again well. Link to comment
