Skywagon Posted April 19, 2010 Share Posted April 19, 2010 I have a multitec that is about 6 months old now. I want to clean the inside. All I could find was clean with a neutral cleaning agent. I wrote to Shoei and asked what that was and could they make a recommendation. I got an answer from a tech that said use shampoo. Does that sound right or should I use something else? Link to comment
mbelectric Posted April 20, 2010 Share Posted April 20, 2010 I run mine through the dishwasher....jus' kiddin'.. I use the mildest detergent I can find. Biosuds at REI. I'm assuming you have detachable liner. MB> Link to comment
japachap Posted April 20, 2010 Share Posted April 20, 2010 Shampoo is good- basically the worry is that if you use anything too strong it will damage the glue or the polystyreen liner. I use very dilute washing up liquid (wait for the howls of derision...) with just a dash of an antibacterial soap or failing that the tiniest tiniest drop of Dettol or bleach. Loads of hot water- not hotter than hand hot - and thorough rinsing with lukewarm water. The inside of my Shoei Raid2 is still good after four years. Conclusion- shampoo good... antibacterial hand soap also good... Link to comment
