Picinisco Posted April 26, 2010 Share Posted April 26, 2010 Anyone know where I can send my twinmax for service. Does not appear to be working? Link to comment
ltljohn Posted April 26, 2010 Share Posted April 26, 2010 Found this link on ADV Rider. It goes to the manufacturer site which is in French. I don't know how much help it will be but it's a start. Link to comment
Picinisco Posted April 26, 2010 Author Share Posted April 26, 2010 Found this link on ADV Rider. It goes to the manufacturer site which is in French. I don't know how much help it will be but it's a start. I have emailed the en anglais but no reply. Link to comment
Sailorlite Posted April 26, 2010 Share Posted April 26, 2010 I found that the vacuum hoses and fittings inside the case are quite delicate. In particular, one of the hoses was slightly torn and not sealing on its nipple - so I replaced it. An easy repair, but don't know whether it applies to your symptoms. Link to comment
hopz Posted April 27, 2010 Share Posted April 27, 2010 I replaced both little hoses in mine and proceeded with use. If you follow the instructions carefully the process ought to be self calibrating. If the dial does not respond to the centering step, then you likely have an electronic issue in the "brains" (sorry for the technical nomenclature) or maybe the battery... double check the battery. Link to comment
