Bear1 Posted April 28, 2010 Share Posted April 28, 2010 I have an 02 RT and was looking to mount a Nuvi GPS on the bike. Checking the RAM Mounts website last night, they suggested using a mount that attached on the brake reservoir. I really don't want to mount the GPS in that location and was hoping there was some kind of mount available that would allow the GPS to be mounted somewhere near where the handle bars attach to the bike. Does such a mount exist? And if I cannot mount the GPS near where the handle bars attach to the bike, what other options are available short of using the RAM mount on the brake reservoir? Link to comment
Frustrated_Diver Posted April 28, 2010 Share Posted April 28, 2010 Try the RAM ball, the 3” shaft, and the cradle. Cycle Gadgets sold me what i needed to mount a Nuvi 660. By replacing one of the handlebar bolts with a longer one (provided) i have the unit in a very practical place. It does obstruct the right side of the tachometer but i really don’t run in the red very often. Link to comment
Dallas Posted April 29, 2010 Share Posted April 29, 2010 There are other good alternatives out there. I use a Migsel Mount which accepts a RAM ball, then a short arm to my Garmin. Quick and simple. Work well. Puts the GPS right in the center of your visual field so you can glance down quickly and be right back on the road. Link to comment
Don M Posted April 29, 2010 Share Posted April 29, 2010 I mounted my Garmin on top of my tank bag. Used a 4"x10" piece of aluminum, put a 45 degree bend at the end and attached the RAM cradle to it. Used wire ties to attach it to the "D" rings that were on top of the bag. Link to comment
RocketMoto Posted April 30, 2010 Share Posted April 30, 2010 Howza bout this? Our customers really like 'em: 1150RT Techmount I'd suggest a rectangular mounting plate, as well, for better stability with the Nuvi since there's no way to bolt it on - you can use 2" wide heavy duty Velcro, and it won't go anywhere. Link to comment
Bear1 Posted May 4, 2010 Author Share Posted May 4, 2010 If this mount installs near the center of the handlebars, that is exactly what I am looking for. As for mounting the actual GPS, I was hoping to get use something that allowed me to share the GPS between the car and the bike. While Velcro will work in mounting the GPS to the Techmount, I don't think it will allow me to use the car mount when using the GPS in the car. I was hoping to find something like the RAM mount that allows me to "pop" the GPS out of the bracket holding on the bike so that I can use the car mount when using the GPS in the car. Is there such a mount from Techmount? Link to comment
Sheepherder Posted May 4, 2010 Share Posted May 4, 2010 try ths link good folks and they are quick to ship http://www.cyclegadgets.com/Products/RAM/ Link to comment
Penforhire Posted May 4, 2010 Share Posted May 4, 2010 I've got the RAM mount they originally suggested to you (cradle from GPSCity). I like that the placement does not block my view of the instruments and the OEM RT tank bag fits fine. Link to comment
RocketMoto Posted May 5, 2010 Share Posted May 5, 2010 Bear: The reason I suggest the wider mounting plate is you put a strip of Velcro towards the rear sides of the GPS, not in the center. This way, you can still snap it into the car cradle. Make sense? Link to comment
