94aero Posted May 3, 2010 Share Posted May 3, 2010 I have AVi and the riders connector is bad. Where is the repair shop? Link to comment
RocketMoto Posted May 4, 2010 Share Posted May 4, 2010 This is the lead from the AVI that you plug your headset into, correct? If so, it's part #1592. We can send you one if you call us; it's an easy plug-in install. Or send the unit we can install it and return to you. Or, if you don't ride with a passenger and the passenger lead is long enough to reach where you plug in your helmet lead, you can just swap the leads inside the AVI. Link to comment
John Bentall Posted May 4, 2010 Share Posted May 4, 2010 +1 on what Adam says. Do not plug a helmet with a ambient noise sensor fitted into the passenger lead - swap the leads over first. Hope this helps Link to comment
