johnlt Posted May 7, 2010 Share Posted May 7, 2010 Where is the TWI on the Pilot Road II tires. I've looked even with a magnifying glass and just cant seem to find them. TIA Link to comment
Firefight911 Posted May 7, 2010 Share Posted May 7, 2010 John, Go to the edge of your tire. Look 1-1/4" up from the edge inside one of the large tread lines. It should be there. If not in that particular one, go to the next large groove until you find it. They will be spaced every four large grooves apart. Slide your finger along the tread groove and you will feel them. They are shallow in height, measuring maybe 1mm, but they are there. In line with this one are the rest in each of the grooves across the cross section of the tire. Link to comment
johnlt Posted May 7, 2010 Author Share Posted May 7, 2010 Thanks Phil, I think I might have found them. They are quite subtle, not very obvious. Thanks agian, john Link to comment
