CruisinCruzan Posted May 20, 2010 Share Posted May 20, 2010 Has anyone used the Wunderlich vario-levers on their RT. I want the lever closer to the grip than the stock adjustments will allow. I have plenty of room to get closer and still allow full actuation. If you have installed them will it accomplish what I want or is the distance the same? Thanks Link to comment
ScottM Posted May 21, 2010 Share Posted May 21, 2010 I checked out the vario levers at Javit's center this year and although the salesperson said they would adjust closer than stock, they didn't feel closer to me and when I measured the distance they were not different. Scott Link to comment
allikanbe Posted May 22, 2010 Share Posted May 22, 2010 Does the RT not have the lever adjuster behind each lever like the K1200 models have? I can adjust my levers quite a bit with the adjuster. I also have the vario levers that are adjustable. If I recall, the vario levers are closer than I was able to adjust with the OEM levers (but don't quote me on that). I've had them on for 2 years. Link to comment
CruisinCruzan Posted May 23, 2010 Author Share Posted May 23, 2010 The RT levers are adjustable from really far away to ridiculously far away Link to comment
hANNAbONE Posted May 25, 2010 Share Posted May 25, 2010 tRY tHIS : http://www.pazzoracing.com/ Link to comment
