Deek Posted June 11, 2010 Share Posted June 11, 2010 Looking for a source for handlebar risers for a 2010 R1200RT. Link to comment
Deek Posted June 12, 2010 Author Share Posted June 12, 2010 I was told those risers than fit a 2006 will also fit the 2010 R1200RT. Anyone know for sure? Link to comment
hopz Posted June 13, 2010 Share Posted June 13, 2010 Maybe a call to Suburban Machinery, or a look at the A&S on-line catalog will get you an answer. Maybe even your dealer can tell you if the mounting points are the same. Link to comment
Deek Posted June 13, 2010 Author Share Posted June 13, 2010 Maybe a call to Suburban Machinery, or a look at the A&S on-line catalog will get you an answer. Maybe even your dealer can tell you if the mounting points are the same. The dealer was not sure, but I checked with a couple of vendors, and was told the older risers will work on a 2010, but that only 3 of the 4 bolt holes in the risers would be used, as the 2010 has only 3 bolts compared to my 06 which uses four. Odd that. Link to comment
