SinNH Posted July 13, 2010 Share Posted July 13, 2010 Bike Bandit says a /60 is what I ordered even though all of the other fourteen front tyres I have ordered on line I made no mistakes and got a /70. So,the difference is 1/2" (12mm) in height and I'm going to run it. Other than a slight change in bike angle and maybe a little bit rougher feedback from the front I don't think there will be much difference. I'll put up with it for 5-6000 miles. What say you guys ? 2000 R1100RT Bridgestone BT023 Link to comment
dsl Posted July 13, 2010 Share Posted July 13, 2010 If I didn't have written documentation to back-up a /70 order, then I'd run the /60 (previous /70 orders don't matter, you might want to try new sizes). Two things to be concerned with: A /60 has less side tread - but that shouldn't matter unless you ride extreme lean angles (you'll have smaller chicken strips though). And pothole protection - keep the tire properly inflated, and watch for potholes/sharp edges - BMW rims are soft. Link to comment
Sailorlite Posted July 13, 2010 Share Posted July 13, 2010 Where are the speedo and odo pickups? If they're from the front wheel, the smaller tire will read 4% too high, which shouldn't be much of a problem. Link to comment
SinNH Posted July 13, 2010 Author Share Posted July 13, 2010 Thanks all, and a good point the speedo pick-up is on the front axle. Steve Link to comment
krussell Posted July 13, 2010 Share Posted July 13, 2010 Do you have ABS? I'm wondering if the speed sensor difference will matter? I take it Bike Bandit doesn't accept returns? Link to comment
motoguy128 Posted July 13, 2010 Share Posted July 13, 2010 Do you have ABS? I'm wondering if the speed sensor difference will matter? I take it Bike Bandit doesn't accept returns? I should recalibrate itself when you first start moving. Thsi helps compensate for tire wear. A /60 should give a little better feedback form the front end and make the steering a little more responsive since you'll have a little more weight over hte front, and a little bit steeper head angel. Yamaha used to always use a /60 on their R6 I think for that reason. Link to comment
SinNH Posted July 13, 2010 Author Share Posted July 13, 2010 Bike Bandit accepts returns yes, but I sort of need tyres very soon. The weird part about the emails that verified my order with BB, is that I just started using them last month when I went through a 1970 Honda CB 350 for a customer and all the parts were itemized on the emails they sent me (2) and with the Bridgestone tyres they just listed their part # and "Bridgestone Tire". Oh well. Probably go back to using Comp Acces for tyres,,,just because I KNOW, I ordered a 120/70, I always check and recheck before placing the order. Steve Link to comment
