doc47 Posted July 20, 2010 Share Posted July 20, 2010 Our non-motorized single-tracker brothers and sisters know how to do things the light and simple way. We can learn from them. These are high-quality products at minimal prices. Their service is first-class! (Usual disclaimers, etc.) Planet Bike Air Pumps Link to comment
Alan D Posted July 20, 2010 Share Posted July 20, 2010 I started with that stuff. I would not go back. Link to comment
elkroeger Posted July 20, 2010 Share Posted July 20, 2010 Considering the cost and weight of these, vs. 12V mini pumps, I'm not sure there's much advantage. Certainly a lot more work anyway. If you're fond of the mini bicycle pumps check out the Topeak Road Morph. It's actually a mini floor pump - which is probably a worthwhile upgrade. Link to comment
elkroeger Posted July 20, 2010 Share Posted July 20, 2010 **Hijack alert** doc47 - did you see this one? Salad spinner centrifuge **End of Hijack** Link to comment
Dave39 Posted July 21, 2010 Share Posted July 21, 2010 One of my cycling/motorcycling friends carries a Road Morph on his motorcycle, but it's going to take a lot of exercise to pressure up a motorcycle tire using it if he ever has a flat. The volume of air pumped with each stroke is very low. I use a Morph on my Litespeed but a 12v Slime pump on the RT. Link to comment
doc47 Posted July 22, 2010 Author Share Posted July 22, 2010 I have a 12v Slime pump and it has crapped out on me. Lots of noise, very little air! I had a similar, homemade one that I cannibalized out of a Fred Meier special; one of those ones in a big, plastic box. I'm sure it's the same as the one in the Slime pump. Looks the same, anyway. Worked fine but this one in the Slime pump ain't hackin' the biscuits. Pumping by hand is a lot of work but in the back of beyond I want reliability!! Link to comment
BeemerLover Posted July 22, 2010 Share Posted July 22, 2010 I was at my Autozone store this past weekend and saw a 12v portable tire inflator for about $10. It was compact in a plastic zippered case and would pump a car tire up to 35 lbs. Might be worth a look. Link to comment
Dave39 Posted July 22, 2010 Share Posted July 22, 2010 My Slime is still going strong after a couple years. Haven't had to use it to pressure up a flat, but it's handy for topping off tires occasionally on tours. Link to comment
outpost22 Posted July 23, 2010 Share Posted July 23, 2010 When in Baja with 3 other riders, we were constantly airing up and down several times a day, depending on sand, rocks and pavement. The other 3 guys brought manual air pumps. I brought a small 12V pump. Guess which one got used the rest of the trip after the first day. Link to comment
skinny_tom (aka boney) Posted July 23, 2010 Share Posted July 23, 2010 The problem with a lot of smaller 12v pumps is that the piston is made of plastic. It wears out after a while. I can't tell you what a while is because I didn't keep track of running time of my last cheap one. I sure that how long it runs each time makes a difference because of heat, as well as total time. Now I'm using a more expensive one, and so far haven't had a problem. Of course, I now also carry a super small hand pump just in case. Link to comment
doc47 Posted July 23, 2010 Author Share Posted July 23, 2010 Outpost and Boney, What brands of pumps are you using? Link to comment
skinny_tom (aka boney) Posted July 23, 2010 Share Posted July 23, 2010 Outpost and Boney, What brands of pumps are you using? I have the expensive Cyclepump from Best Rest I can't vouch for it's longevity as I've not "fully" tested it. However, it so far has lasted considerably longer than a $39 Sparrow. When I'm out in the woods I also carry a cheap super-miniature hand pump for bicycles just in case. I haven't been left by a power pump, but the Sparrow failed (without notice) once when I was going to air-up the tires for a long pavement stretch. It just ran forever without adding any air to the tire. I rode with low air pressures- no big deal, but if the tire had been flat.... Link to comment
outpost22 Posted July 26, 2010 Share Posted July 26, 2010 Mine is a Campbell Hausfeld small portable (about 5" x 5" x 2"). Four years later, it still works. I think it cost about $25.00(?) Link to comment
motoguy128 Posted July 28, 2010 Share Posted July 28, 2010 I had one of those floor pumps. It was perhaps the shortest lived pump I ever owned. The check valve failed after just 2 years of use. I've had walmrt pumps last longer. Link to comment
johnlt Posted July 28, 2010 Share Posted July 28, 2010 My BMW /5s and /6s had hand pumps mounted to the frame under the seat as standard equipment. I had to use it once many years ago and it indeed worked. Now I carry a Cycle Pump from Best Rest. Expensive but has never let me down. Link to comment
