Nevets Posted July 26, 2010 Share Posted July 26, 2010 I have a new Motorola Droid X and would like to use it with my Autocom Active Plus. Anybody done it, and or know what cable to use? thanks for any info... Link to comment
krussell Posted July 26, 2010 Share Posted July 26, 2010 Do you have anything else in your system, like a Zumo? If you do, pairing the phone with the Zumo via bluethooth, and wiring the Zumo to the autocom might be the easiest approach. Link to comment
Nevets Posted July 27, 2010 Author Share Posted July 27, 2010 Sorry, I forgot to indicate I was looking into a wired solution. I do not have a Bluetooth interface for my Autocom. I believe it may be a 4-conductor 3.5mm plug on one end of the cable (that's what the earphone/mic had that came with the Droid X). Link to comment
malcolmblalock Posted July 27, 2010 Share Posted July 27, 2010 I'm using a Motorola Droid with my Autocom, and it works great. However, I use a Bluetooth Dongle for my connection. With the Droid using a micro USB connection on the phone (not the mini USB like other phones), I doubt that you'll be able to cable it. Bluetooth dongle costs a lot more than a wired solution, but the connection is usually rock-solid, and the quality of conversation is great. On the other hand, if you can find the cable, go for it! If your Droid X has a mini usb connection, you can probably find a cable that works. Link to comment
Nevets Posted July 27, 2010 Author Share Posted July 27, 2010 Ok, more specifics..... I want to use the 4-pole audio jack on the top of the phone. Link to comment
John Bentall Posted July 27, 2010 Share Posted July 27, 2010 Autocom do 3.5mm 4-pole cables - #2198 is such a 16" cable. HTH John Link to comment
