johnlt Posted July 31, 2010 Share Posted July 31, 2010 Has anyone used one of the available small vacuum pump systems to bleed and/or change their brake fluid. I know about the speed-bleeders which are a simple check valve nipple but the vacuum pump allows you do do the bleeding/replacement from the caliper nipple. Link to comment
GordonB Posted July 31, 2010 Share Posted July 31, 2010 I found mine to be a pain in the a**. Too much hassle with air leaking around the hoses and nipples. If you're doing your '07 RT the local dlr can do it for less than $100. In fact you can have my MityVac for the cost of shpg. Link to comment
Shaman97 Posted July 31, 2010 Share Posted July 31, 2010 I tried Harbor Freight's version of the MityVac - more trouble than it was worth. I saw an electrically powered vacuum pump that worked very well, though at a Tech Daze. Lotsa bucks for a DIY'er, I think. Switched to the Speedbleeders - life is now good. Link to comment
Sidmariner Posted July 31, 2010 Share Posted July 31, 2010 I use one frequently and will never go back to the old way of bleeding brakes. Used in conjunction with Speed Bleeders, they greatly reduce the time it takes to bleed a system. I don't find them messy at all. To the contrary, I found the old system of dangling a loose hose in an old jam jar or coke bottle to be a greater nuisance. Link to comment
BerndM Posted July 31, 2010 Share Posted July 31, 2010 I've used my MityVac on everything from my servo-ABS R1200GS to a KLR250 to a complete drum to disc replacement on my boat trailer. Worked great and I'm sure it really simplified things for me. Link to comment
Brant Herbert Posted July 31, 2010 Share Posted July 31, 2010 I made an investment a number of years ago in a pneumatic extractor like the one linked to below (the canister on right). Use it on all my vehicles. Makes for easy, one-man jobs. Lock the trigger by flipping up the metal wire then just focus on working the zerk with your wrench (and keeping the reservoir full). Was a good investment, I think. < IMAGE > Link to comment
eddd Posted July 31, 2010 Share Posted July 31, 2010 John, I tried using my Hoover. It didn't work to well. Seriously now, I've always used my Mighty-Vac for all my bleeding. It works very well. Easy to control, easy to get the feel for how often you need to stop and refuel. Link to comment
