KevinR1200 Posted August 12, 2010 Share Posted August 12, 2010 I mounted the Starmate4 Sirius radio on my 0912rt. I get two errors while riding: Antenna not connected and searching for signal. I use it in the office/car with no trouble. I have used it on my KLR and my 06 GS with no trouble. I have replaced the mounting dock and antenna - no joy. I have it wired directly to the battery, and I have tried plugging into one of the BMW provided power sockets - NO Change. I have change the antenna mounting location - No change. I have found that it faults when idling on the stand/during acceleration/ while cruising. it is very erratic but not usable on the RT. ANy ideas???? Link to comment
Angel Posted August 12, 2010 Share Posted August 12, 2010 Iv'e had the same error with my sirius radio. My radio has a dock that is installed to the bike via a Ram knob. I have concluded that the constant vibration on the bike is in fact enough to to jiggle the the antennae plug loose. NOW, I know that you are probably thinking that you can't push the plug in any further (so this can't be your problem). That was exactly what I thought for months, (after I was able to confirm that it had absolutely NOTHING to do with cloud cover). Then, one day while my level of disgust/frustration was peaking... I discovered that its not about "pushing" the plug further in, its about rotating the plug while its fully seated. If this sounds a little to sketchy for you... then I won't tell you about the witch doctor and tribal medicine man I had to consult with before I got my music back! Link to comment
jjg3 Posted August 12, 2010 Share Posted August 12, 2010 Is it possible that you have the radio or antenna located near a GPS or other electronic component that may be interfering with the signal? Initially my Sirius radio had a reception problem but it turned out it was because the gps and radio were too close. A remote gps antenna resolved it. Link to comment
ElevenFifty Posted August 12, 2010 Share Posted August 12, 2010 I gave up on temporary mounting and cut a hole in the dash. I mounted a standard docking station with a custom metal strap that is affixed to the dash with two small screws. I hooked up the power (car adapter buried under the dash panel, hooked to ignition switched power), balanced audio cable (runs back to my Starcom but has a 'Y' cable that runs to a plug on my tankbag for iPod) antenna (runs to the top of my dash). After I had all the plugs in place, and before buttoning up the dash, I wrapped several warps of a good quality stretchy electrical tape around the docking station to keep all the connectors firmly attached. I made this mod 3 years and 60K+ miles ago and it has been flawless. EXCEPT - In two torrential downpours enough rain got into the receiver to screw up the display ... it went all black. Both times, I turned off the power and waited for dry weather. Both times it came back just fine. This summer I replaced the original with a black face receiver. The first was silver and is now my garage radio. I made the switch just for the looks ... I like the cool blue display. Advantage is that it is ALWAYS with the bike and is tamper and theft proof. When I'm riding 2-up Sharon controls the Sirius with the remote control. When I find a replacement dash at a reasonable price, I'll redo the mounting for a cleaner look ... Pics are here You'll notice that I also have an in-line analog volume control for the Sirius built into the dash ... I use this to quickly trim the level when I'm using FRS and want to keep the master volume on the Starcom set pretty high. DH Link to comment
