outpost22 Posted August 18, 2010 Share Posted August 18, 2010 Just thought I'd share this. When I first bought the RT 5 years+ ago, I installed the PIAA 1100 series lights on it thinking it was the way to go. Since then, I have found better alternatives. Anyway, one of the bulbs burned out after 13 months. Yesterday (4 years later) the other one burned out. Has anybody else experienced such dramatic bulb life differences? And no, I will NOT spend the money for the PIAA bulbs. I've seen them from $35-$50.00 each. Instead, I just squash the original MR16 lamp and peel it off of the PIAA lens cover. Replacement MR16 bulbs are $4.95 and I use a high temp sealant to mate the 2 pieces back together again. One of these bulbs is now 4 years old and counting. It just is a shock to me that 2 bulbs mounted in the same application should show such a life disparity. Link to comment
bobbybob Posted August 19, 2010 Share Posted August 19, 2010 I've been looking at aux lighting for my GS, and have come to the conclusion that PIAA is not in the lighting business, they're in the *bulb* business. Reminds me of the folks that make the ink-jet printers. Alternative suggestions from anyone?--not looking for night riding range, but rather for daytime recognition. Link to comment
GordonB Posted August 19, 2010 Share Posted August 19, 2010 I had PIAA's in my headlamp assembly and they both burned out right at 18,000 miles, just as the OEM's they replaced did. Brighter? Yes, Longer lasting, Not for me. Link to comment
moshe_levy Posted August 19, 2010 Share Posted August 19, 2010 On my '04RT with 1100x under the oil cooler, both burned out within 2 weeks of each other. I found cheap OEM replacement bulbs on e-bay for $25 each. A rip off, for sure. Now I run HID under my oil cooler, in self contained ballasts that are no bigger than 1100X. One HID assembly complete is $80, so all told much cheaper than a set of 1100X new. We'll see how long they last. -MKL Link to comment
bobbybob Posted August 19, 2010 Share Posted August 19, 2010 Moshe, what kind of HID's do you have? Is that $80 including the housing--or just for the bulb/ballasts? This sounds like something that might work for my GS. But I am completely ignorant about HID's and aux lighting in general--I need help. Link to comment
moshe_levy Posted August 19, 2010 Share Posted August 19, 2010 Trail tech MR11s - http://trailtech.net/round_post_lights.html - they're as small as 1100X and fit under the oil cooler. For a GS, where there's room, I'd go with the larger models, which throw much more light. That $80 buys 1 complete MR11. So far I love them. -MKL Link to comment
bobbybob Posted August 19, 2010 Share Posted August 19, 2010 This is good--thanks! Do you have the flood or spot? I am looking for daytime recognition so am thinking flood would be the way to go... Is the ballast built in to that housing? Link to comment
moshe_levy Posted August 19, 2010 Share Posted August 19, 2010 I have spots. The housing contains everything. -MKL Link to comment
