elkroeger Posted August 30, 2010 Share Posted August 30, 2010 I need a new pressure gauge. Any suggestions for a good quality replacement? Link to comment
Steve Kolenda Posted August 30, 2010 Share Posted August 30, 2010 If it is tire pressure that you are referring to, then I would suggest a digital ROADGEAR. I have had mine for years, it is fairly small and convenient to carry. Steve Link to comment
Penforhire Posted August 30, 2010 Share Posted August 30, 2010 I like inexpensive ($10) digital gauges, any design angled well enough to make it easier to press on the valve. I had a liquid-filled rubber-cased fancy analog gauge for racing ($60 if I recall correctly) and it wasn't more accurate than these digital pressure gauges (usually +/- 0.5 PSI on the cheapest of them). It was just more convenient to see the pressure constantly and it had an integrated bleed system to quickly adjust pressure. I also had to be a lot more careful how I handled it. Link to comment
ltljohn Posted August 30, 2010 Share Posted August 30, 2010 I use the EZ Air It clips to the valve stem and allows easy pressure adjustment. Link to comment
Skywagon Posted August 30, 2010 Share Posted August 30, 2010 I use a slime digital available at most auto part stores. From memory about 10 bucks. Link to comment
markgoodrich Posted August 31, 2010 Share Posted August 31, 2010 I have about six pencil gauges, an electric digital Accugauge, and a dial gauge on a longish hose. They all are within a pound of each other, despite the wide difference in price and deluxe-ness. Link to comment
Larry Posted August 31, 2010 Share Posted August 31, 2010 I agree with Mark. I have been an aircraft mechanic over 40 years. I must have at least 8 gauges, I’ve bought over the years. Some that are more expensive then most riders would pay for or need. One day I was interested, jest like you, and compared the readings. They all read within 2psi.I’d suggest going over to NAPA and picking up a sturdy, made in USA pinnacle gauge. They’ll last a lifetime. Link to comment
rad Posted August 31, 2010 Share Posted August 31, 2010 Like many folks here, I have a very high quality one and inexpensive ones. The only thing I insist on is that it have a bleed off button so I can over fill and bleed it down to the pressure I want. Link to comment
RockBottom Posted September 1, 2010 Share Posted September 1, 2010 I love this one. Accutire Link to comment
longbch Posted September 1, 2010 Share Posted September 1, 2010 I like using the ROADGEAR Talking Digital Tire Gauge with my RT because you don't need to see the numbers when getting around the disc brakes. The only thing I don't like about it is that it's all plastic. Link to comment
Quinn Posted September 1, 2010 Share Posted September 1, 2010 I try to never check tire pressure without a compressor nearby. It's more like an air replacement proceedure. Out with the old, overinflate with new and bleed it down to where it probably was when I started. --- Link to comment
Bologna Posted September 3, 2010 Share Posted September 3, 2010 I use this one in the garage for the bike and autos and have a pencil gauge on the bike that I have checked against the accu gage and only 1psi difference. http://www.aerostich.com/prevent-or-repair/tire-repair/tire-gauges/accu-gage-with-hose.html Link to comment
