Trav1150 Posted September 12, 2010 Share Posted September 12, 2010 Can anyone advise what lifespan I should expect out of a BMW Gel battery? I have had the battery in my R1150RT for well over five years and for much of that time the battery has been connected to a trickle charger when the bike has not been ridden. For a variety of reasons I don't do many kilometres in a year, however before the end of the year I will be making two long trips and don't want to have the inconvenience of a dead battery whilst away. Your thoughts would be appreciated. Link to comment
Paul Mihalka Posted September 12, 2010 Share Posted September 12, 2010 You are way past the average expected life of a battery. I would definitely replace it before any long ride. Link to comment
snod Posted September 12, 2010 Share Posted September 12, 2010 I have had 3 BMW branded gel batteries. Not one of them made it through five seasons. I agree with Paul, replace yours before the trip. Link to comment
boatzo Posted September 12, 2010 Share Posted September 12, 2010 I think replacing that battery before a long trip would be a very prudent move. IMHO, replace it with a AGM battery, much better than a GEL. Link to comment
RichEdwards Posted September 12, 2010 Share Posted September 12, 2010 I'm with the others. Get a new battery. Link to comment
JayW Posted September 12, 2010 Share Posted September 12, 2010 I don't disagree with the advice you have been given, but for what it's worth, my OEM GEL battery is well over 5 years old and still starts the bike as well as it ever did. I never use a maintenance charger but ride every week. It has never been deep discharged and I thoroughly clean and brighten the battery connections every couple of years. I have decided to keep using it and carry a small set of jumper cables just in case it fails unexpectedly. I would not risk it if I were riding in areas of isolation though. Jay Link to comment
longjohn Posted September 12, 2010 Share Posted September 12, 2010 I don't disagree with the advice you have been given, but for what it's worth, my OEM GEL battery is well over 5 years old and still starts the bike as well as it ever did. I never use a maintenance charger but ride every week. It has never been deep discharged and I thoroughly clean and brighten the battery connections every couple of years. I have decided to keep using it and carry a small set of jumper cables just in case it fails unexpectedly. I would not risk it if I were riding in areas of isolation though. Jay How well does it start on 32 degree or colder mornings? That's when I noticed mine was almost finished. Link to comment
moshe_levy Posted September 13, 2010 Share Posted September 13, 2010 The BMW battery (likely a garden variety rebadged Exide Gel) will give you an average life of 4-5 years measured at +25C constant. The enemy of battery life is heat, so those in cooler climates can get a little more time out of them, while those that live in hot climates a little less. When they die, like all gels, they do very suddenly, usually at the most inconvenient time. Yours has given you more than your money's worth - replace it before the big trip. -MKL Link to comment
racer7 Posted September 13, 2010 Share Posted September 13, 2010 5 yrs is quite a while for the stocker and most would say you are due for a new one. However, new ones can sometimes be crap so I'd be darn sure to do it a while before I hit the road, just to be sure I didn't buy a clunker that will get me stuck on the road. There is only 1 objective way to test a battery that is worth the time to do it and that is a load tester that shows how many amps the battery can deliver into a starting load. If it tests good re load, it is good, so there is no reason to discard it. Checking by voltage measurement is of no utility. Link to comment
Trav1150 Posted September 13, 2010 Author Share Posted September 13, 2010 Thanks for your responses everyone. It looks like a new battery is in order. Removing the tupperware to access the battery by the side of the road is no joy, particularly when your mates are keen to keep touring. Link to comment
jslyter Posted September 13, 2010 Share Posted September 13, 2010 My 1150RT, purchased new in early August 04 still has the OEM battery in it, so it is over 6 years old (currently has about 35K miles on it and gets rotated onto a tender every couple of weeks in the winter). I considered replacing it before a trip up to Canada in June, but it seemed to still be cranking strong so I went with the OEM. It was in the back of my mind the whole trip though, especially some of the colder mornings. I'll probably get an AGM in the next month, so I don't have to think about it anymore. Peace of mind is a good thing, especially when you are far from home. Link to comment
