BHS Posted September 20, 2010 Share Posted September 20, 2010 So my final drive seems to be leaking. It is dripping at the rear pivot area, not the frame pivot. My guess without yet taking it apart would be a failed pinion shaft seal? Anyone have any previous experience with a leak in this area? Thanks. Link to comment
Hall Vince Posted September 20, 2010 Share Posted September 20, 2010 Worth checking it's not running down the tunnel from gearbox output? \v/ Link to comment
BHS Posted September 20, 2010 Author Share Posted September 20, 2010 I don't think so, if that was the case wouldn't there be some leaking around the rubber boot? That seems dry. Link to comment
Jerry Duke Posted September 20, 2010 Share Posted September 20, 2010 It sounds like the pinion gear seal. More annoying than anything else, but if it's a low mileage bike, it could mean the gear mesh is too tight and causing the pinion gear to move putting pressure on the seal. With all the problems with these final drives, I would have it checked out. Link to comment
BHS Posted September 20, 2010 Author Share Posted September 20, 2010 Bike is an '06 with 87,000 miles. Anyone here ever change that seal? What special tools will I need? I turn wrenches for a living and prefer to do my own work whenever possible. Link to comment
