johnlt Posted September 26, 2010 Share Posted September 26, 2010 After returning from Torrey, I was inspecting my tires because they are nearly in need of replacement. These are PR-2s with 9K miles. Prior to leaving for Torrey, I had an "even" 3mm of tire depth to the wear bars. I rode about 1800 miles and now still have nearly 3mm to the inside (center) but only 1mm to the outside of the tire. I've never seen this kind of wear on a rear tire. Could it be the inside is the harder compound and the outside is softer and with Torrey's rough roads and many twisties, it wore mosly the outside. See pic below: Link to comment
Paul Mihalka Posted September 26, 2010 Share Posted September 26, 2010 The Pilot Road 2 is a dual compound tire with the center harder than the sides. You simply had too much fun! Besides with 9K miles from a tire you have nothing to complain about... http://www.michelinmotorcycle.com/index.cfm?event=pilotroad2 Link to comment
dsl Posted September 28, 2010 Share Posted September 28, 2010 Sounds normal enough to me.... this is a set with half your mileage. Link to comment
