ednowicki Posted November 16, 2010 Share Posted November 16, 2010 I have a Zumo 550. I frequently use the left-hand hard buttons to flip through MP3 selections. Yesterday, when I got home from a ride, I noticed my ‘-‘ rubber button was gone, leaving the hard button unusable and the printed circuit board/micro switch exposed to the elements. The rubber membrane must have worn/eroded around the button and broken off. So this does not happen to others, I would suggest the following: 1) Treat the rubber to some “armor all” like product, and 2) Inspect your buttons for cracks. If you see cracks try using “goop” to seal the crack/rot. Link to comment
donbmw Posted November 16, 2010 Share Posted November 16, 2010 I had my power button come off like that. I had found a rubber plug the same size that fit tight and was going to use that. On the zumo Forum I found the link below were you can by a demo Zumo and order one and replace the case. It was only $20.00 alot less than $150.00 send it to Garmin. Email or call and ask about the demo cases they are not list on the web sit. http://www.tvnav.com/ Link to comment
Nesbocaj Posted November 17, 2010 Share Posted November 17, 2010 Hey Don, Looked at that site and didn't find the 'demo' case, any help bud? Link to comment
donbmw Posted November 17, 2010 Share Posted November 17, 2010 The cases are not listed on thier site. You need to email and ask about the case or call them. The email tha comes back will have the cost which when I did mine was $20.00. It will also till you how to order. Link to comment
