Question about headset chargers
Hollow Road Rider
Hollow Road Rider
I am not sure if I am splitting hairs here, but I am not electronically savvy, so bear with me.
I have a new helmet and SRC headset. The headsets are made by Cardo. The label on headset charger says the output is 5.0 Volts & 1.0 Amps. I have an extra phone charger with the identical mini USB fitting that lists the output at 5.1 Volts & .07 Amps.
Can I use my phone charger on the headset without damaging it?
I do all the time - whatever charger & cable happens to be available. Mine are all 1A or near that - I expect your ".07Amp" is really "0.7Amp" and that just means it charges a bit slower.
Hollow Road Rider
Right, I meant 0.7 Amp.
Thanks.
Hollow Road Rider
Don't use one with higher amperage or you risk damaging the battery.
So, higher voltage is OK?
