Heyfrank Posted May 29, 2011 Share Posted May 29, 2011 Has anyone used a bluehooth dongle with a 3.5 m connector that will charge and signal at the same time? I have a dongle bt1002 by agpek hooked up to a amplirider mixer and it sends fine on battery mood. I have it hooked up to bike power with adapter from radio shake but it won"t send in charging/power mood. This is going to my Sena unit.Thanks Link to comment
YaekoCubr1501 Posted May 30, 2011 Share Posted May 30, 2011 I think it will not do both the things at a time. But, still You need to check connections properly and take a advice of a motor mechanic. Link to comment
Heyfrank Posted May 30, 2011 Author Share Posted May 30, 2011 I thought someone running the chaterbox or camos bluetooth dongle might know if it would run /send while charging. there are other dongles also but under discriptions of product they don"t say if they do above. Welcome to forum. I may call rocketmoto on tuesday. Link to comment
TF1200RT Posted May 30, 2011 Share Posted May 30, 2011 I bought one of these with the Charge Block that is made by the same company. It says it will work when it is being charged, but you would still need to charge your headset (limited by the charge on the headset). Link to comment
Heyfrank Posted May 31, 2011 Author Share Posted May 31, 2011 Thanks for information. I have a email to Sena about the sn10. That was suppose to come out in Feb of 20011 to see if that will run on bike power also. do you run that unit that you posted ?I also wrote kokkia about the A10. They said that would also run while charging. I am still trying to learn how to post links. Another day I guess. Thanks Link to comment
Troy Posted May 31, 2011 Share Posted May 31, 2011 The Chatterbox dongle that I have will charge and work at the same time. Link to comment
scoops Posted May 31, 2011 Share Posted May 31, 2011 I use a "Scosche Universal Stereo Bluetooth Transmitter for MP3 Player" plugged into the 3.5mm jack on a Zumo 550. This functions while charging and gives me stereo music to the Sena. Link to comment
Heyfrank Posted June 1, 2011 Author Share Posted June 1, 2011 Thanks for the help. the kokia A10 at this time seems to be the smallest with same features. Link to comment
Heyfrank Posted July 6, 2011 Author Share Posted July 6, 2011 I tried the kokkia and it does not work when being charged. I guess the saleman that replied did not know. It also shuts off after 5min and has to restart with button. I guess I should ask, does the chatter box turn on and off if connected to a switched circuit. Does it have a on and off button. My goal is to just turn on key and the bluetooth will reconnect to sena. Thanks all. Link to comment
